Pocket GPS World :: View topic - tomtom speed cam help
speedtouch2511
PostPosted: Thu May 15, 2008 2:16 pm    Post subject: tomtom speed cam help Reply with quote
hey guys
i have installed the speed cams to my tomtom one xl.ok all enabled with warning sounds.have downloaded and installed custom speed cam icons also.the problem i have is when the speed cam alert shows up on the screen as just a red square and not the custom icon i wanted to user.any help on this please
PostPosted: Thu May 15, 2008 4:42 pm    Post subject: Reply with quote
When you copied the camera files to the map folder did you copy all the files that were in the download or just the files that end with .ov2 each camera category comprises of an ov2 file (the actual date) and a coresponding .bmp file which is the icon.
If the bmp files are missing the TomTom will use a default red square instead.
If you think you sent the entire download to the device download it again and try for a second time, it could have been your download that was corupted for some reason - Mike
PostPosted: Thu May 15, 2008 4:46 pm    Post subject: Reply with quote
You've not given us much detail to go on...
Is it the database from this site?
Are the "custom icons" from this site? If so, which ones?
A couple of pointers to get you going:
The normal icons must be 22x22 pixels square, they must be bitmap images not jpegs, and they must have exactly the same name as the POI datafile they got with.
For example, for the 20MPH Gatso camera file from here "pocketgps_uk_gatso_20.ov2" you need an icon file called "pocketgps_uk_gatso_20.bmp".
You CAN intall additional double sized icons which are used for the large flashing display in the corner of the screen (instead of the system scaling up the normal ones), but these are optional.
Also you must check your PC is setup to show the three letter extensions to every file, otherwise it is very easy to name your icons something like "pocketgps_uk_gatso_20.bmp.bmp" by mistake.
If you have used the icons from this site and not changed anything, they should work fine.
speedtouch2511
PostPosted: Fri May 16, 2008 6:25 am    Post subject: re tomtom speed cam help Reply with quote
hey guys
sorry for the late post was on nights.any way i installed the speed camera database from this site and also the custom icons below
http://www.pocketgpsworld.com/speed-camera-icons.php
i copyed over the bmp files {custom} to map section on tomtom.all that shows up as i approch a cam is a red square,im guessing its the default image for cam.i used the 48 by 48 icons by the way.
Oldboy
PostPosted: Fri May 16, 2008 6:53 am    Post subject: Re: re tomtom speed cam help Reply with quote
The larger bitmap Files are for the flashing corner display.
If you are going to use those you also need the standard size (22x22) that come with the camera download. These are the icons that show on the Map.
You should have:
Temp.ov2
and, optionally, Temp.ogg
speedtouch2511
PostPosted: Fri May 16, 2008 12:50 pm    Post subject: Re: re tomtom speed cam help Reply with quote
You should have:
Temp.ov2
thanks old boy for the info.ok i would like the icons to show up and not flash so could you surgest a size of icon please.
Oldboy
PostPosted: Fri May 16, 2008 1:29 pm    Post subject: Re: re tomtom speed cam help Reply with quote
Unfortunately the flashing Icon is not customisable. It flashes at the first warning and then stays on solid until the camera is passed.
It's only the corner icon that flashes.
Personally I like the 22x22 and the Double Size 44x44 set.
22.055 (29 May 24)
