Pocket GPS World :: View topic - Camera Database for other Countries - How to Load?
dazzuk
PostPosted: Sat Apr 19, 2008 1:19 pm    Post subject: Camera Database for other Countries - How to Load? Reply with quote
I have the Navman F20 with UK mapping and your speedcam dbase loaded up to date.I am travelling shortly in Australia and have SD card mapping for there,and have downloaded speedcam info as well.Do I load this the same way?Is it loaded to replace the UK speedcam info?Is it loaded in addition to UK info? Can anyone help please? Thanks.
Brickie64
PostPosted: Sat Apr 19, 2008 6:24 pm    Post subject: Reply with quote
DazzUK
You'll be downloading the AUS database which has files named such as "pocketgps_aus_specs_60.asc"
The names are different to the UK files you'll have loaded previously so you won't be replacing any of the UK files you've already added (unless you run out of memory or have exceeded the maximum number of POI files you can have).
The Australia files should run alongside the UK ones without any problems.
I'm pretty sure that the POI files are resident in the on board memory on the device so it shouldn't matter if the memory card with Australia is fitted when you add the camera POI files.
Hope this helps.
Gav
"A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible"
Garmin Nuvi 3598 + GO 720 (+USA Map Card) + NavFree for iPhone in case all else fails ;-)
