Pocket GPS World :: View topic - Putting a splitter onto a 760 - is it possible
Miles_hot
PostPosted: Fri May 16, 2008 9:40 pm    Post subject: Putting a splitter onto a 760 - is it possible Reply with quote
As my question about the "dead" 360 seems to have stumped everyone it looks like I will be buying a new unit - given that O've just purchased a couple of splitters to improve the traffic reception on the 360 can I use these to do the same for the 760?
I am assuming so given that the excellent review at the top of this forum seems to show that there is a shoelace included on the charging cable however I thought I'd check!
Many thanks in advance
Miles
philpugh
PostPosted: Fri May 23, 2008 2:04 pm    Post subject: Reply with quote
It should be possible.
Is it the GTM21 unit? That's what I have and I used a cheap splitter to connect it to my car's amplified aerial.
If your car has an amplified aerial you will probably have to use a capacitor to block the 12V from the GTM shoe-lace just to be safe. It also prevents any nasty shorting possibilities.
It's well worth the effort to do this - you will get significantly improved reception.
Phil
