Pocket GPS World :: View topic - X950 - X950T Convertable?
RebelDJ
PostPosted: Mon Jan 21, 2008 1:00 pm    Post subject: X950 - X950T Convertable? Reply with quote
Hello all - first post on site!!
I have tried to search out the difference between these two models, and as far as I have seen it is just the TMC antenna. SO, if this is correct, could the X-950 be converted to a X950T by just adding a TMC antenna, or is there some other alteration that needs to be done as well? Is this something that is possible, or if you want traffic information do you have to buy a "T" model to start with?
Gee-Pee
PostPosted: Mon Jan 21, 2008 5:03 pm    Post subject: Re: X950 - X950T Convertable? Reply with quote
Does the X-950 have a traffic module aerial socket? That might be the answer Wink
Gee-Pee
Lifetime member PGPSW - time rapidly decreasing
RebelDJ
PostPosted: Mon Jan 21, 2008 7:47 pm    Post subject: Re: X950 - X950T Convertable? Reply with quote
That does seem obvious, doesn't it? But the reason I asked is that thequickstart manual says "connect your external TMC antenna to the input jack (headphones socket located along the top ...". So, does the headphones socket count as the "traffic module aerial socket"? And do you need to do anything else?
Thanks for your help,
Gee-Pee
PostPosted: Mon Jan 21, 2008 8:53 pm    Post subject: Reply with quote
Mmmm! Not so simple as I thought. I wonder if someone out there has a X-950T and could compare. Mine is a different model so I cannot help. Wink
Gee-Pee
jonandmarkuk
PostPosted: Mon Jan 21, 2008 9:57 pm    Post subject: Re: X950 - X950T Convertable? Reply with quote
Sounds a little too good to be true if you ask me. I would imagine if the T model is a lot more expensive then it would contain an FM tuner, the other model may not contain the tuner in order to pick up the signals or everyone would buy the cheaper model and hook up a cheap aerial to get TMC
BigPerk
PostPosted: Tue Jan 22, 2008 10:23 am    Post subject: Re: X950 - X950T Convertable? Reply with quote
I am inclined to be a bit cynical like jonandmarkuk.
But to answer your question above, in the X980T which I have, the detailed V7 user manual off the VM site (covers all 3 models and always worth downloading) shows that you use the Main Menu/SET/Setting Adjustment/'Activate headset\TMC' option to toggle between headphones and TMC - but if johnandmarkuk is right, I assume you may find you don't get this option offered for your model either. If you seem to have the various TMC options available, the only way to prove one way or the other would I suppose be to connect some sort of aerial lead (with an appropriate connector of course) and see. But I suggest you don't hold your breath!
(Navigon 70 Live, Nuvi 360)
ivecoviv
PostPosted: Tue Jan 22, 2008 4:19 pm    Post subject: 950 T Reply with quote
I have a 950 T and have purchaced a cable from VM it does give wareings of hold ups when selected,The cable plugs into the socket next to the on off s/w.on the settings menu you have a Trafic info icon,if you don't have this then you won't get trafic info.On the back is a lable showing X950T on the 950T and it shows 950 on the 950.The 950 has a socket in the sane position as the 950T.Hoe this helps.
IvecoViv
22.054 (22 May 24)
