disney_cjd Occasional Visitor
Posted: Wed Jan 23, 2008 11:32 pm Post subject: Help please. What files on the device and then on SD |
Hi All
I am confused (unlike Al Murray who was never confused!)
I have a 520T with a 2GB SD card. A few questions that are bugging me are:
1) I used the latest map g-tee and was given Great Britan and Rep Ire map 7.10 today instead of teh UK & Ire map 7.05 that was installed. This downloaded to my SD Card. Question is - on the TomTom it calls itslef the UK and Rep Ire Map and not the GB map - is that right?
2) I also bought the North American 2gb map for the 720 from the Map Store and added this to the 2GB SD card also. Seems to work fine. Question though, on the SD card and in the device memory do I need to have
- all voices on both
- pois on both
- safety camers etc on both
Or can I just have all teh voices on the SD for example and use this with the Map on the device?
Thanks for your help
Craig |
Andy_P Pocket GPS Moderator
Posted: Wed Jan 23, 2008 11:57 pm Post subject: |
Quite a few questions!
Firstly the map name... this doesn't matter at all. TomTom often give new versions different names. In fact this is preferable... if they had the SAME name, how would you know which was the newest one when you went to choose one on the "switch map" page?
As for where to put things, the 520/720 and 920 are different from previous models in that you CAN use both the Internal memory at the same time.
I would suggest you stick with the 'normal' layout where the operating program, and voices, etc would stay on the internal memory. You can then put maps on either the memory or the SD card slot.
As for speed cameras and other POIs, they MUST be put in the specific map folder they are intended for. This means that if you want them available on all your maps you have to copy them into all the map folders.
If you want to get rid of the old UK map and put the replacement one on the internal memory instead, that is easy to do, just shout if you need help.
Finally, do you really need to keep ANY of the UK maps now you have the Western Europe map? It has the same coverage of the UK and Eire as the UK and Eire maps do, so you only need the WE one. |
Posted: Thu Jan 24, 2008 12:09 am Post subject: |
Hi Andy
many thanks
Sorry if I confused you, I do not have the WE map. I have these three now
UK & Rep or Ire 705
Great Brit and Rep or Ire 710
North American 2GB 710
I have deleted I think teh UK & Ire one but just removing it using the Home software
I have added the computer voice for the USA to the internal memory
So the layout I hope is this
Internal: GB & Rep Ire maps, UK and USA computer voices, safety cams
SD card: NA maps, US retail POIs
One thing on POIs. I do not seem to have any to pick from home apart from useless ones like t mobile hotspots etc. Am I doing something wrong?
Craig |
Posted: Thu Jan 24, 2008 12:38 am Post subject: |
Sorry about Europe map confusion... all my fault, I'm not used to using a laptop and scrolling up and down with the trackpad or page up/down buttons is such a pain, I didn't scroll back to your message as often as I'd normally do!
Your layout sounds fine, the POIs and speed cams will be in their map folders if they are showing up OK.
One thing I'd suggest. From what you say, it sounds like you are the type of person who likes to know how things work and to do things "properly".
If so, get the GO connected up to the PC, shut down Home and start having a look at where things are, just by using Windows Explorer.
You'll learn more in 5 minutes than a lifetime of doing things via Home.
The Go will appear as two new drives on the PC, one for the internal memory, one for the SDcard.
Normal voices will be in a folder called "voices", Text to speech voices in "loquendoTTS", Maps will be in folders with obvious names like "UK and IE" and pois will be ".ov2" files inside those folders.
Don't mess with anything untill you know what you're doing, but the first thing you SHOULD do is a complete backup of EVERYTHING on both memory and SD card using Explorer (as "Home" backups often don't work!)
There is a good walk through on how to do it in the FAQs HERE
Any more questions, just ask! |
Posted: Thu Jan 24, 2008 12:48 am Post subject: |
a-ha. You know me well and no worries on the laptop front. I often reply to forums on my blackberry - thats hard work.
Thanks for the tips. I will do teh explorer back up tomorrow and take a nose around. I am impressed with the USA maps though. It has our road on it which is two years old and some resturants which opened up like 6 months ago.
One thing I did read was that some of the 920 users have not got all the text to speech files. Do you know what I need to check to make sure I have? I did download them from the link I was given but if I do not need them .....
I see there are lots of POIs on here also. I might take a nose at thsoe also.
Cheers for all of your help. Hopefully I cna klearn more adn then repay the new newbie hahaha!
Craig |
Posted: Thu Jan 24, 2008 3:08 am Post subject: |
I've not followed the discussion that closely, but I think it was the SPEECH RECOGNITION files rather than text to speech that was missing.
If I remember rightly it was that you couldn't use SP on a Europe map on a US purchased unit and vice versa.
The missing files should be in the map folders and be called "cspeech_GBR", "cspeech_FRA" etc. |
