VintageRifle Occasional Visitor
Posted: Sun Dec 16, 2007 5:35 pm Post subject: TomTom One 3rd Edition Custom POI error |
Hello,
I have been working on a custom POI database for use on my TomTom One 3rd Edition. TomTom version 7.163
Everything started out just fine and was correct until I added a few more POIs to the data file. I now have a category with with red square, a "." before the name, and no POI found when selected.
Name looks like this after the red square: .Shooting Ranges
I also have the complete category, with custom icon, and all POIs included.
What have I messed up and how can I fix it?
Thank you for your help. |
Posted: Sun Dec 16, 2007 5:39 pm Post subject: |
What is the name of the POI file? |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Sun Dec 16, 2007 7:04 pm Post subject: Re: TomTom One 3rd Edition Custom POI error |
VintageRifle wrote: | Name looks like this after the red square: .Shooting Ranges | Try deleting the "." from the name either on the Unit, or on the PC and copying back to the Unit.
The TT can't create a POI Name with a "." as the first character, so it does recognise it correctly when you offer it one.
The Red Square is there because the POI Name doesn't match the Bitmap Name. _________________ Richard
Posted: Sun Dec 16, 2007 7:32 pm Post subject: |
The .ov2 file name is Shooting_Ranges.ov2
I cannot find any other files that start with a dot.
Contents of the USA_and_Canada Folder:
cline.dat
faces.dat
Fire_stations.ov2
USA_and_Canada.pna
Shooting_Ranges.ov2
DeletedPoi.local
poi.dat
School.ov2
tables.dat
traffic.inc
USA_and_Canada-5.meta
tmccodes.dat
traffic.dat
MapSettings.cfg
MapUserPatch.dat
cname.dat
mapinfo.dat
Playing field.ov2
USA_and_Canada-5.meta.dct
cnode.dat
Toledo_Zoo.ov2 |
Posted: Sun Dec 16, 2007 7:48 pm Post subject: |
I suggest single click on each file, hit F2 and retype the name of each file to make sure there are no extra "." any where.
Won't hurt or take 10 seconds to try..... |
Posted: Sun Dec 16, 2007 10:52 pm Post subject: |
When I remove the Shooting_Ranges.ov2 file and the Shooting_Ranges.bmp file, the red dot fantom file also goes away. Seems there is an error in the written file that ghosts a second empty .ov2 file. |
Posted: Sun Dec 16, 2007 11:48 pm Post subject: |
In Windows Explorer, Tools, Folder Options, View, make sure that Hide Extensions for known File Types is UN-Ticked.
Also select Show hidden Files.
To Windows a "." has special significance in the Folder hierarchy. Whether it has in Linux I don't know. _________________ Richard
Posted: Tue Dec 18, 2007 3:30 am Post subject: |
Did not find any odd file names. I ran the .ov2 file through another editor and saved it. Took care of the problem. Not sure what was up with the error to begin with. |
dmunsil Occasional Visitor
Posted: Thu Jan 10, 2008 10:34 pm Post subject: |
I'm seeing this same issue, or rather someone else is seeing this issue on their One XL with OV2/BMP files that work fine on my Go 510.
When he installs the OV2 files, he gets bogus categories listed with a period in front of their names, and a red square for the icon. And when he selects the categories, it says something like "No POIs found!"
On my 510, everything works tickety-boo. I'm currently working through testing the following hypotheses:
- One of the POI uses a character than the One XL doesn't like
- One of the POI has a name that's too long
- The file name itself has a character the One XL doesn't like
- The BMP files aren't in a format the One XL likes
Anyone else have an idea?
If you want to try the files yourselves (they're POI for the Walt Disney World area), they're on this page:
http://www.mousesavers.com/gps.html
Or here's the direct link to the zip file of OV2/BMPs:
http://www.mousesavers.com/MouseSavers_TomTom.zip
Again, these exact files work fine on a Go 510.
Don Munsil |
strik Occasional Visitor
Posted: Fri Jan 11, 2008 1:46 am Post subject: |
Ha ha... Hey dmunsil, to quote from a Disney line, its a small small world.
I'm 99.9999% sure I'm the fellow who's having the problem you've been trying to help. I've been Googling around for a solution and came across this thread. Still no luck.
A couple notes:
I've tried multiple POI files from various sources and I always get the problem. I get a "." then a space then the name. When I select it, I get "No POI found!"
I've tried hitting the reset button
I've tried doing a hard reset
When I look at the files, on my computer, they look ok. They don't have the "." or anything.
Would love to get a suggestion, or maybe I have to exchange this one at BestBuy? |
Andy_P Pocket GPS Moderator
Posted: Fri Jan 11, 2008 2:45 am Post subject: |
This sounds like it might be connected to TomTom stupidly changing the format of their own POI files (to "type 100").
Try opening your problem ov2 files in POI Edit and then resaving. No promises, but it might help. |
Posted: Fri Jan 11, 2008 3:02 am Post subject: |
I tried that - the original files had been generated with MakeOV2 (v. 1.1), as it seemed like the safest bet. I tried regenerating the files from scratch using POIEdit, and the same problem occurred.
Since then he's tried downloading some other OV2 files from tomtomforums.com, and had the same issue. It's possible there's something wrong with his unit, but I'm continuing to explore other possibilities. If someone else with a One XL gets it working, then that would suggest that it's just his unit, but for now I only have two data points - mine and his.
Thanks much for the suggestion!
Don |
GerryC Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/web.jpg)
Posted: Fri Jan 11, 2008 4:06 pm Post subject: |
dmunsil wrote: | Since then he's tried downloading some other OV2 files from tomtomforums.com, and had the same issue. It's possible there's something wrong with his unit, but I'm continuing to explore other possibilities. If someone else with a One XL gets it working, then that would suggest that it's just his unit, but for now I only have two data points - mine and his. |
Just downloaded them to my One XL and they show up fine (granted, I can't find a route to them as they are 4500 miles away ). I have never seen this issue on my XL but one thing I did notice was that the icons are 24x24 pixels but that should just make the icon a red square if the firmware was not recent enough.
My understanding is that Windows cannot have a filename starting with a dot but Unix can. _________________ Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount |
Posted: Fri Jan 11, 2008 4:32 pm Post subject: |
GerryC wrote: |
My understanding is that Windows cannot have a filename starting with a dot but Unix can. |
HaHa! Just typical that Microsoft have this big thing they keep pushing called ".Net" then! ![Laughing](modules/Forums/images/smiles/icon_lol.gif) |
Posted: Fri Jan 11, 2008 5:33 pm Post subject: |
Kind of off-topic, but actually, you can create a file that begins with "." in Windows, at least since Win95. Explorer (the main Windows shell) will stop you from doing it, but using a command window or another program there's no problem.
Just open a command window and type something like "notepad .foobar". It'll ask you if you want to create a file ".foobar". Hit "Yes", select save, then quit. Back at the command window, type "dir" and there's the file. It's hidden from explorer windows, even if you have "show hidden files" turned on, which is interesting.
As to this problem, FWIW my current thinking is that it's caused because Strik is using a Mac, and it's saving both the main file and a hidden "resource" file that begins with "._". Macintosh files have a data fork and a resource fork, and on non-Mac formatted disk drives and SD cards it has to store two files to get both forks.
If that's true, then either he needs to use a low-level file manager to copy the files over, or he needs to delete the extraneous "._" files after copying the files over, or figure out a way to get the Mac to suppress the extra files for files of type OV2, because it doesn't do this behavior for every file type, it appears. If it "knows" the file type doesn't need a resource fork, it doesn't bother creating one. How that happens, I don't know.
I remember dealing with this problem years ago on a mixed network of Macs and PCs, but that was like 1991, and I haven't seriously used a Mac since around '94.
Don |
