Pocket GPS World :: View topic - Tom Tom One V2 Battery life
jc50
PostPosted: Thu Dec 13, 2007 7:09 pm    Post subject: Tom Tom One V2 Battery life Reply with quote
How long should the battery life be when the unit not in use ?
If the battery discharges completely will I lose anything ?
Oldboy
PostPosted: Thu Dec 13, 2007 8:55 pm    Post subject: Reply with quote
I'm not too sure what the shelf life is, probably 2 or 3 weeks.
You won't lose anything because the data is stored on the SD Card.
If the battery had gone totally flat, after a re-charge it will read the SD Card on Boot Up when you switch on.
GerryC
PostPosted: Fri Dec 14, 2007 12:41 am    Post subject: Reply with quote
Just in case others read this, it isn't the case with internal memory that could be lost if the battery discharges. That's what happens with my PDA. Mad
jc50, if you know your unit won't be used for weeks, then I'd suggest you keep a Windows backup just in case.
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
wibbly
PostPosted: Fri Dec 14, 2007 11:45 am    Post subject: Reply with quote
There's also a sequence I can't recall (somebody help please) that properly powers down the device, stopping the background drain. On start-up it then does a 'cold boot'.
I really don't understand why the 'standby' drain on these devices is so high. It's not as if it has to be doing anything useful (except perhaps keeping the clock going)
Oldboy
PostPosted: Fri Dec 14, 2007 12:50 pm    Post subject: Reply with quote
Like This? Smile
wibbly
PostPosted: Fri Dec 14, 2007 12:55 pm    Post subject: Reply with quote
Oldboy wrote:
Like This? Smile
Ha ha! I thought it was familiar - I started that thread Embarassed
Thanks Oldboy
tanda
PostPosted: Fri Dec 14, 2007 2:15 pm    Post subject: Reply with quote
PDA's loose everything when the battery is flat, because everything is stored in RAM, and you need power for the RAM. Doesn't the TomTom have a hard drive, the ones without an SD card, so you won't loose anything?
Audi A3 Sline sat nav
22.063 (19 Jun 24)
