stuart Frequent Visitor
![](modules/Forums/images/avatars/3066899624b1791e6d5756.jpg)
Joined: 20/04/2003 11:51:10 Posts: 405 Location: Dorset, England, Great Britain
Posted: Mon Oct 08, 2007 6:27 pm Post subject: Navman F30 |
I have been using my Competition Prize since it arrived direct from Navman in August 2007. At first all was fine, including the TMC. But after updating last months cameras, the unit has failed big time. It won't accept Post Codes, and now crashes after 10 seconds from switch on. One of my wise sons has tried it out with the same results, resulting in a 30 minute loss in Brighton yesterday. Anyone else suffer from this F30/20 crash. Help required please. |
Gee-Pee Lifetime Member
![](modules/Forums/images/avatars/2753245604985889cd11f6.jpg)
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Tue Oct 09, 2007 12:54 pm Post subject: Re: Navman F30 |
stuart wrote: | I have been using my Competition Prize since it arrived direct from Navman in August 2007. At first all was fine, including the TMC. But after updating last months cameras, the unit has failed big time. It won't accept Post Codes, and now crashes after 10 seconds from switch on. One of my wise sons has tried it out with the same results, resulting in a 30 minute loss in Brighton yesterday. Anyone else suffer from this F30/20 crash. Help required please. |
I cannot give you a definitve answer, Stuart, but have you tried the usual fixes? ie Try a hard reset: press the reset button on the bottom of the device and leave it a couple of minutes, then restart. (It may reset/re-start on its own). If it is like my N20, the reset button switches it off then you have to press again to restart. On restart, the device starts and reloads the software and is known to sort a lot of device sickness.
Alternatively, try taking out the memory card - wait - and then re-insert it.
If these don't work get on to Navman tech support either by email or phone. Check your manual for contact details. ![Wink](modules/Forums/images/smiles/icon_wink.gif) _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
Posted: Wed Oct 10, 2007 6:16 pm Post subject: F30 |
Gee-Pee. Thanks for you response. Yes, I have done all the usual re-sets. Pin in the small hole and a full reset from the preferences. I have contacted Navman and got a reply today to ring them direct, which I shall do. All the memory is internal, so no SD card used. |
Posted: Wed Oct 10, 2007 7:11 pm Post subject: Re: F30 |
stuart wrote: | Gee-Pee. Thanks for you response. Yes, I have done all the usual re-sets. Pin in the small hole and a full reset from the preferences. I have contacted Navman and got a reply today to ring them direct, which I shall do. All the memory is internal, so no SD card used. |
Ok, didn't know that but did have a look at the F30 Manual. Hope your conversation with Navman helps....Ihave always found them to be quite helpful on the phone or by email or indeed when I have visited them...I don't think that is encouraged though.
Let the Forum know how you get on! ![Wink](modules/Forums/images/smiles/icon_wink.gif) _________________ Gee-Pee
Johnny_D Regular Visitor
![](http://i106.photobucket.com/albums/m273/Johnny_w_D/200px-Blackadder_IV_-_Goodbyeee-1.jpg)
Joined: Mar 04, 2006 Posts: 119 Location: West Suffolk
Posted: Fri Oct 12, 2007 8:11 am Post subject: |
Try this :-
Hold down the big middle button and then turn it on. you will be (hopefully) presented with the 'hidden' menus.
You can do some further hard resets and system tests.
Might be worth a go.
JD _________________ TTG 300 Died the death of a cracked screen
Navman F20 USB Fell off
TTG 520 Third time lucky?
Bloody Superb PGPSW Camera Database.
Not much else! |
TheM Frequent Visitor
Posted: Mon Oct 15, 2007 5:06 am Post subject: Re: Navman F30 |
stuart wrote: | crashes after 10 seconds from switch on |
Do you have enough time before the crash to check if shop demo or route demonstration are activated? If you do, first make sure that they are both turned off.
It could be that speed cam data you downloaded got corrupted in the process. Can you update again? |
Posted: Tue Oct 16, 2007 1:31 pm Post subject: F30 Crashing |
TheM. Thanks for that info, I'll look closer then next time it crashes.
Johnny_D. Cheers for that help, amazing what you can do with outside help. |
