Pocket GPS World :: View topic - Using the Route 66 cam database-how do U set warnings?
MrMrMr
PostPosted: Fri Oct 05, 2007 12:38 am    Post subject: Using the Route 66 cam database-how do U set warnings? Reply with quote
on Route 66, using the Route 66 camera database it loaded ok, but how do you set it to warn you when you approach it, I know Tom Tom has a function to warn when near cammeras can you not do this on Route 66?
Also why is there no postcode search? or am I lookin in the wrong place?
cheers
PostPosted: Fri Oct 05, 2007 7:29 am    Post subject: Reply with quote
What version of Route 66 are you using and on which type of device?
For POI Warnings on the PPC version I use Main Menu/ Points-Of-Interest/ POI Alarm, select the POI category you want from the list
Set the position where the warning should be displayed
Set a distance
The final screen allows you to select a sound file and set warn only on route (if you want this)
Full postcode support only became a supported feature on more recent releases of the software, my version supports three digit postcode but will not use full seven digit codes - Mike
MrMrMr
PostPosted: Sat Oct 06, 2007 4:29 pm    Post subject: Reply with quote
its a WM6 device Asus A696.
I think its Route 66 v7
PostPosted: Sat Oct 06, 2007 5:22 pm    Post subject: Reply with quote
It looks quite a nice device you have there, I would have a read through the instructions I posted a while back on configuring Route 66 for the Speed Camera Database which can be found Here
The WM6 OS should not be an issue, I have R66 running on my Artemis which I upgraded to WM6 last night and it warned of cameras when I used earlier today (I do have an activation problem however since changing the OS, but this is a seperate issue) - Mike
22.064 (26 Jun 24)
