Pocket GPS World :: View topic - Speed Cameras in .poi format?????
Southy
PostPosted: Fri Dec 30, 2005 4:28 pm    Post subject: Speed Cameras in .poi format????? Reply with quote
Does a list exist in this format. The new ViaMichelin X-930 requires POIs in this format.
lbendlin
PostPosted: Sat Dec 31, 2005 5:26 am    Post subject: Reply with quote
can you give us a link to the specifications for that format?
Lutz
TomTom/TeleAtlas NAVTEQ
Southy
PostPosted: Sat Dec 31, 2005 8:34 pm    Post subject: Reply with quote
no link is available.
When you use POI Manager (part of ViaMichelin software) it doesn't recognise the ASC format used in other versions of this software.
Additionally if you download POIs from teh Michelin website these come in POI format.
lbendlin
PostPosted: Sun Jan 01, 2006 12:31 am    Post subject: Reply with quote
Then send us some of these POI files and we'll have a look.
Lutz
jazzzhead
PostPosted: Mon Sep 04, 2006 2:38 pm    Post subject: Reply with quote
Hi Southy,
I was wondering if you managed to track down a link to the "Speed Camera" POI's for the X-930. I have just bought this model but cant find a link on this site.
Thanks in advance
Chris. Confused
spocsta
PostPosted: Wed Aug 08, 2007 11:28 pm    Post subject: Via Michelin Website Reply with quote
Hi I have purchased a subscription to Poket GPS World for the database, and have the same problem with my X-930 - I have now found that if you register (for free) on the Via Michelin website, you can now download a free camera database for free - updated every month. After finding this out I contacted Pocket GPS World and asked for a refund (same day as subscribing) only to be told no - very disappointed with PocketGPSWorld - but check out Via Michelin website - camera database comes in as a POI file and works well!!!
PostPosted: Thu Aug 09, 2007 9:11 am    Post subject: Reply with quote
this post: http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=292526#292526
implies that our database is fully compatible with the vM x950 so would also assume it works with the x930 and x970
Paul-m
PostPosted: Fri Aug 10, 2007 8:11 am    Post subject: .ASC and .poi Reply with quote
Just for clarity...
The PGPS speed cam files work perfectly with VM. You import them as personal POI's and then set up the warnings as per the guide.
The issue is that you can only get a warning sound as opposed to a spoken alert.
If you use VM's own fixed speed camera file then you get a spoken alert which uses test to speech so it gives speed and distance warnings.
The drawback here is that VM's file is only for fixed cameras and is not as comprehensive as PGPS files.
The VM data is contained in a .EXE file which uploads a .POI file to the device makinf installation easy.
Given that VM have sponsored PGPSW events and must be on good terms. Would it be possible for VM to supply PGPS with a method of creating the .POI files?
Paul
Wife 3 kids.... unversity fees...:-(
oh... and a few PC's and gadgets ;-)
22.064 (26 Jun 24)
