Pocket GPS World :: View topic - Confusion over dbases
JIS
PostPosted: Fri Jul 20, 2007 9:20 pm    Post subject: Confusion over dbases Reply with quote
I have been downloading the UK POI dbase for the past year (downloading to my Garmin 2720). However, I am off to France next week so I thought I'd download the European dbase which supposedly includes the UK ? Imagine my surprise when I noted that the UK dbase has 10,000+ entries whereas the European dbase has but 7000 or so.
I have verified that my local speed traps are no longer visible so have clearly been deleted / over-written.
What should I do please?
John Stephen
Tunbridge Wells
Kent
JockTamsonsBairn
PostPosted: Fri Jul 20, 2007 10:17 pm    Post subject: Re: Confusion over dbases Reply with quote
John Stephen
Tunbridge Wells
Kent
I presume you're talking about the PGPSW Speed Camera database? What made you think that the European database also included the UK one?
Jock
JIS
PostPosted: Sat Jul 21, 2007 5:48 am    Post subject: Re: Confusion over dbases Reply with quote
Yes, it's the speed camera dbase that I was discussing.
Yes, I assume that the European dbase would include the UK because the UK is part of Europe Wink If I had wanted to differentiate between the two I might have named the latter Continental Europe. However, what would you recommend as I cannot update my Garmin with another dbase as I cross the channel ! Laughing
Thanks !
John
JockTamsonsBairn
PostPosted: Sat Jul 21, 2007 10:57 am    Post subject: Re: Confusion over dbases Reply with quote
Thanks !
John
Historically the database started for the UK. Then holiday makers started reporting what they had seen. The option was then to create a DB for each European country, with the overhead that would create or have a single "European database (not including UK) for your holidays". Given that these numbers were much smaller than the number reported in the UK the latter seemed most logical (This is all guess/conjecture on my part, but sounds likely in theory. Someone will correct me if I'm wrong.) There is a table here that gives you the comparative numbers.
As far as the use of the DBs on your Garmin, I don't use one myself. Have a search through the Garmin forums, because there has been discussion about mixed databases recently.
Jock
missing_user
PostPosted: Sat Jul 21, 2007 11:31 am    Post subject: Reply with quote
I cannot answer for the garmin in question but for my Garmin 60CSX I would use the UK zonned database [unzipped to a known location] and then add the unzipped Continental cameras to the same location, and then load them to the Unit with Garmin POI loader from the file. You then have all the POIs loading at the same time 'overwriting' the existing camera locations.
Is this what you wanted to know or have I mis-read your posting?
JockTamsonsBairn
PostPosted: Sat Jul 21, 2007 12:19 pm    Post subject: Reply with quote
I think some of the info I read, but now can't find, had to do with conflict between the MPH UK Db and the KPH Euro Db.
[Edit]
Have a look at this.
But, be aware that
swing wrote:
If you search the forums there are a number of suggestions for having both mph and kph alerts at the same time - basically you either change the values in one set of files to the other units, or you use the multiple POI Loader upload tricks (not available on all units).
If Swing sees this thread, maybe he will clarify which units can/cannot use this workaround?
[/Edit]
Jock
Last edited by JockTamsonsBairn on Sat Jul 21, 2007 1:57 pm; edited 1 time in total
PaulB2005
PostPosted: Sat Jul 21, 2007 12:46 pm    Post subject: Reply with quote
If you used POILoader to load the new database then it wipes out all exisiting POIs first. In order to load both database you need to put them both into the same folder on your PC and then upload them both at the same time using POILoader.
JIS
PostPosted: Sat Jul 21, 2007 4:52 pm    Post subject: Reply with quote
Thanks all, I have now downloaded both France and UK into the same folder and successfully downloaded the lot. However, I do have the concern that nt Garmin could possible assume that kph based limits / speed cameras are in fact mph 8O
Can anyone clarify the position please?
missing_user
PostPosted: Sat Jul 21, 2007 5:04 pm    Post subject: Reply with quote
When in this country set you Unit to mph and in France to kph!
[statute and metric]
22.094 (25 Sep 24)
