PaulBt Lifetime Member
![](modules/Forums/images/avatars/2136747795467701b51f073.gif)
Joined: Sep 22, 2006 Posts: 188 Location: Kempsford, UK
Posted: Fri Jul 06, 2007 3:36 pm Post subject: Navigate to Favourite - route not found |
I wanted to add a hotel into a TT910, that I knew I would only use a few times over one weekend, so when parked (in the carpark) I simply added the GPS position as a favourite, rather than selecting a POI catagory for it.
The trouble came when cold wet and tired, we wanted to get back to the hotel, and TT said "no route found" 8O
Lots of mucking around then ensued.
The outcome of which was if I had set the location as a POI TT would have found a route to the nearest point on a road, but as a favourite with no road there it said there was no route available.
Is this normal
Paul _________________ TT720 V8.010, regular audio book user.
WestEuro v805 connected to E90 on O2
TT910 V6.525, TTN5, TTN3, TT on Psion 5mx |
46jimbo Regular Visitor
Posted: Fri Jul 06, 2007 3:51 pm Post subject: |
When setting a favourite, it's best to do it close to the road at the entrance to the parking lot. Going away from the road just confusing the TT.
However, I didn't realize that it worked differently if it was set as a POI rather than a Favourite. |
Posted: Fri Jul 06, 2007 4:19 pm Post subject: |
Paul, have a read of This Thread from last year which I think is the same problem, for some strange reason storing off road locations is possible and you can navigate to them, but you have to enter them from the browse map options for the location to be used for subsequent navigation - Mike |
Posted: Fri Jul 06, 2007 4:41 pm Post subject: |
Trying it again here, in the office
I did the following tests:
1. From main menu pg2
add favourite
GPS position
2. From main menu pg1
Change Prefs
prefs pg2
Manage POIs
add poi
(choose a catagory)
In "add as POI pg2" GPS position. :D
3. From main menu pg2
add favourite
Browse Map
select blue arrow ( top right hand corner)
Done. :D :D :D
So solution 2 gives you a POI while solution 3 gives you a favourite.
How strange
Posted: Fri Jul 06, 2007 4:53 pm Post subject: |
I did say the method of entry to get this to work is strange, not sure why there is such inconsistent behaviour but at least you now know how to overcome the issue - Mike |
Oldboy Pocket GPS Moderator
Posted: Fri Jul 06, 2007 6:11 pm Post subject: |
From Browse Map you can do both. Add as Favourite or Add as POI. _________________ Richard
