Pocket GPS World :: View topic - clock on tom tom one
beans
PostPosted: Tue Jun 26, 2007 9:29 am    Post subject: clock on tom tom one Reply with quote
I have a tomtom one original and notice recently when turning on that the clock is often showing the wrong time
does anyone know why.
Regards, Beans
Oldboy
PostPosted: Tue Jun 26, 2007 10:24 am    Post subject: Reply with quote
Which version software are you using?
This used to be a problem on all the devices using early software versions.
voice_of_reason
PostPosted: Tue Jun 26, 2007 12:34 pm    Post subject: Reply with quote
Continuing the theme....
Does the TomTom ONE ever sync its clock automatically from the satellites? I noticed there's an option in the menus to do this, and it seems to work, but I'd have thought it would make more sense to autmatically sync the clock every time it gets a satellite fix - but I'm not sure that it does this.
PostPosted: Tue Jun 26, 2007 1:24 pm    Post subject: Reply with quote
Nope. AFAIK it only syncs when you tap the button. It also only syncs the minutes or seconds, as there is no other allowance for different time zones.
beans
PostPosted: Tue Jun 26, 2007 8:57 pm    Post subject: Reply with quote
Hi Richard,its running version 6.150
Oldboy
PostPosted: Tue Jun 26, 2007 9:33 pm    Post subject: Reply with quote
I can't remember if I had a problem with that version or not.
I know I don't now. Smile
Gmonkey
PostPosted: Wed Jun 27, 2007 10:15 pm    Post subject: Reply with quote
From what I've read, the device prompts you to enter a time manually. However, you CAN sync it with the satellite - however, the time zone will be set to GMT. You must change the time zone manually.
Hope this helps!
trevor.dowle
PostPosted: Sat Jun 30, 2007 1:23 pm    Post subject: Reply with quote
Hope this helps!
I asked a similar question several months ago, when I had problems when I synched, and TomTom continuously set itself to UTC.
The solution is to synch the time, which will display in UTC, then alter the hours to BST and synch again. This sets the memory to BST.
Regards
Trev Dowle
TomTom 730 T
beans
PostPosted: Sat Jun 30, 2007 2:32 pm    Post subject: Reply with quote
Thanks everyone,
Beans
22.064 (26 Jun 24)
