Pocket GPS World :: View topic - Garmin - Rubbish basic routing
xspartx
PostPosted: Tue May 22, 2007 5:51 pm    Post subject: Garmin - Rubbish basic routing Reply with quote
Garmin 360
Terrible compared to my old Medion.
1. Insists on sending me on the M6 instead of the M6 Toll
2. Often tells me to leave a motorwary on an exit, then recalculates and takes 5 mins off my estimated journey time when I ignore it.
3. Is hopeless around my home, sending me WAY out of my way.
4. To cap it all the estimated time of arrival is very bad, and with no customisable options.
Very disappointed.
alix776
PostPosted: Tue May 22, 2007 6:03 pm    Post subject: Reply with quote
from memory they use the same maps ( medion and garmin) what route setting are you using
device Lumia 950 xl
xspartx
PostPosted: Tue May 22, 2007 8:32 pm    Post subject: Reply with quote
Fastest.
tomthompson
PostPosted: Tue May 22, 2007 8:49 pm    Post subject: Reply with quote
fastest means heading for motorways and doing longer journeys .Even on TomTom and virtually every other make.
If you know the area then use your brain and let the gps get you out of trouble if it all goes belly up.
Asus Zenfone 2 twin sim, Garmin Zumo 550, 660 and pocketgps speed camera database
I keep on learning but they invent new things faster ,How do I keep up ?
xspartx
PostPosted: Tue May 22, 2007 9:05 pm    Post subject: Reply with quote
Of course..........but the Medion took me via the "best" route without any trouble. Thats my point.
PostPosted: Tue May 22, 2007 9:19 pm    Post subject: Reply with quote
from what i understand the m6-toll is longer than the m6 equivalent hence it takes you on the fastest route. even if you have avoid toll roads turned off then it'd still avoid the tm6 toll due to it being longer.
if you want to go on the toll road just go on the toll road and it'll recalculate
xspartx
PostPosted: Tue May 22, 2007 9:32 pm    Post subject: Reply with quote
I know m8, I am just saying that the Medion worked this out automatically. i.e. it must have known that the Toll road gives a shorter journey time than the M6.
philpugh
PostPosted: Wed May 23, 2007 10:55 am    Post subject: Reply with quote
Only if someone told it. Laughing
It may depend upon your destination. I have noticed that my nuvi ignores the M6Toll if my destination is SW of B'ham but chooses it if it's SE - which would seem about the right behaviour for fastest/quickest routing - given the distance differences. But in reality (for most times of the day) it's a no-brainer - the M6T is faster and easier to drive - so take the toll road and the nuvi will catch up very quickly!
Always bear in mind that these devices are not to be followed slavishly. If you know where you are going - you don't need one. They are very useful if you don't know where you are going though - but you still need to use your experience as a driver to question the route choice from time to time.
Phil
tynecomp
PostPosted: Wed May 23, 2007 12:43 pm    Post subject: Re: Garmin - Rubbish basic routing Reply with quote
The reason there are no customisable options is that the Nuvi learns over time how fast you drive on different classes of roads and then uses this information to estimate time of arrival. You should find that after a few days use the estimates improve.
philpugh
PostPosted: Wed May 23, 2007 5:44 pm    Post subject: Re: Garmin - Rubbish basic routing Reply with quote
Does it then use the 'modified' speed to plan a route. I.e. if you drive slowly on unclassified roads does it stop routing us down them? I can't say I have noticed this or a change to estimation of journey time on my 660 yet Smile
Phil
tynecomp
PostPosted: Wed May 23, 2007 6:47 pm    Post subject: Re: Garmin - Rubbish basic routing Reply with quote
I believe not, unfortunately.
xspartx
PostPosted: Wed May 23, 2007 11:14 pm    Post subject: Reply with quote
Today it sent me home via a different route, from the same motorway junction.
ATM Medion beats Garmin in the route stakes
sunstrip_steve
PostPosted: Thu May 24, 2007 8:17 pm    Post subject: Reply with quote
This depends on where it starts navigating from. If you start off the road network it does tend to think of 2 different ways as it picks an exit point and then works out the route from there. so 2 different exit points - 2 different routes
22.062 (12 Jun 24)
