Pocket GPS World :: View topic - download error
download error
aj2052
PostPosted: Tue May 08, 2007 1:15 am    Post subject: download error Reply with quote
I note a slight problem with the supermarket download, the download shows 2 entries for Morrisons Coalvile.
i.e
Morrisons, Whitwick Road 52.73020 -1.36369 and
Morrisons, Coalville 52.72880 -1.363369
But the second one does not show on the submit map, so cannot be amended, the first one is correct and the second one does not show on the tomtom map anyway and seems to be an erronious entry.perhaps MaFt or oldie could check this out.
aj2052
PostPosted: Thu May 10, 2007 10:49 pm    Post subject: Reply with quote
Bump
Daggers
PostPosted: Thu May 10, 2007 11:37 pm    Post subject: Reply with quote
Zoom in to the highest possible magnitude on the map, then switch to Hybrid format and zoom in even further.
Even if the aerial photos aren't good enough to display at that magnitude, you will still be able to see the POI icons overlaid, and see enough of the Morrison's icon to select it and then delete it in the normal way.
aj2052
PostPosted: Thu May 10, 2007 11:59 pm    Post subject: Reply with quote
Thanks Daggers, I had just tried to locate it just prior to your post and couldnt even see it on the Map at Max zoom tucked under Focus, and tried to submit but couldnt because i couldnt show an ID, when I changed to Hybrid mode then could zoom in further and see an overlap and identify ID, just goes to show we learn something new everday, now reported. and now shows light over Focus.
22.071 (03 Jul 24)
