Pocket GPS World :: View topic - Do i3 and nuvi 300 use same in-car power leads?
Bojarski
PostPosted: Wed Apr 11, 2007 3:54 pm    Post subject: Do i3 and nuvi 300 use same in-car power leads? Reply with quote
I am thinking of upgrading my Garmin, the i3 is hard wired into tha car electrics (still using the original plug) When I pass on my old unit to my brother can I just swap leads?
swing
PostPosted: Wed Apr 11, 2007 7:02 pm    Post subject: Reply with quote
The Nuvi range use a mini usb connector, I don't believe this is the connector used by the i3, but if it is, then it will work fine.
Please don't be offended if I do not reply to a PM - please ask questions via the forums.
swing
PostPosted: Wed Apr 11, 2007 7:03 pm    Post subject: Reply with quote
Sorry, I should clarify this - this is true for the Nuvi 300 you mention, but other newer models in the range use a different connector, which is definitely not compatible with the i3.
PostPosted: Sat Apr 14, 2007 1:06 am    Post subject: Reply with quote
my nuvi 350 uses the same lead as my i3...
Bojarski
PostPosted: Sat Apr 14, 2007 10:23 pm    Post subject: Reply with quote
Thanks to all for your help, I'll check before I buy.
PostPosted: Mon Apr 16, 2007 12:26 am    Post subject: Reply with quote
or at least i've been using both with either with no problems!
