Pocket GPS World :: View topic - speed limit numbers to small to read for OAP
rsharrock
PostPosted: Wed Jan 09, 2008 12:22 am    Post subject: speed limit numbers to small to read for OAP Reply with quote
on a Garmin nuvi 200 is there any way to have a louder alert noise or better still a voice alert for speed camera ahead max speed 30mph (for example)
or a bigger font showing the max speed allowed as I have trouble seeing the small print on nuvi screen
PhilHornby
PostPosted: Wed Jan 09, 2008 1:34 am    Post subject: Re: speed limit numbers to small to read for OAP Reply with quote
The Nüvi 2xx isn't .mp3 capable - so the Voice Alert option isn't available. There is a possibility of using ASH10's software (see the stickies) and changing some of the .wav files that make up the standard alerts. You can make them marginally louder (and a lot more distorted) doing that. You might be able to make them more obtrusive, by recording your own. (You'd only be looking to change the low-pitched "BONG" that's used for Proximity Alerts and the higher-pitched "PING" that's used for Speed Alerts)
Your best bet is external amplification (of some description), plugged into the headphone socket. Anything from a cheapo 'iPod' type amp., to an 'FM' transmitter or one of those 'cassette' interfaces. The latter two options would involve sacrificing your radio listening.
GerryC
PostPosted: Wed Jan 09, 2008 1:25 pm    Post subject: Re: speed limit numbers to small to read for OAP Reply with quote
rsharrock wrote:
on a Garmin nuvi 200 ....... or a bigger font showing the max speed allowed as I have trouble seeing the small print on nuvi screen
Though I did a set for TomToms, they are standard bmp images so I suspect they would work on Garmins as well. You will probably need the 22x22 set.
To load them instead, after unzipping the camera file, overwrite the bmp images in that with the ones from my site before doing the POILoader bit.
Note that I haven't tested these on a Garmin so if someone would like to chip in with any thoughts, please do so.
Here are some examples:
You can download them from here.
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
22.054 (22 May 24)
