Pocket GPS World :: View topic - acer n35
acer n35
darlyn
PostPosted: Wed Jan 10, 2007 11:44 pm    Post subject: acer n35 Reply with quote
i have a acer n35 an want t use it in my lorry but cant get the charger to work when i put on it lock up when it in the 12v cig lighter in lorry i know it is 12v iput it in my self as i only had 24v in lorry
theripper
PostPosted: Thu Jan 11, 2007 1:16 am    Post subject: Reply with quote
I think you will find that the charger supplied with the N35 is 12/24 volt
Mine was
theripper
buster0007
PostPosted: Sat Jan 13, 2007 2:21 pm    Post subject: Reply with quote
Hi I see you are running tt with the acer n35 I also have a n35 but it cant find the gps I have tried all the settings on all the comm. Ports and still it wont find the gps can you tell me if you have a driver or a utility on your n35 to allow it to work many thanks
Brian566
PostPosted: Sat Jan 13, 2007 10:30 pm    Post subject: acer n35 Reply with quote
I think all acer n35 have this problem i could understand it if it had poor signal but not GPS not found
I think its aproblem with when you shut down programd Min can be up to 50 minutes before signal or never
But if you do a soft reset it should find GPS in 10 minutes this seem to re start it
But it is a poor unit for GPS signal
buster0007
PostPosted: Sun Jan 14, 2007 12:20 am    Post subject: Reply with quote
Hi thanks for the reply but it does not start to look for satellites the red and black circle does not turn on any settings this is why I was asking if it needs a driver or utility the blue light does flash though if I look in programs or settings there is nothing in there to set up please help
Pc-Mobile
PostPosted: Sun Jan 14, 2007 2:39 am    Post subject: Reply with quote
This is what happens with Navman Pin570 and it may be the same with n35:
Every time you turn off the PDA and on again you have to turn on the GPS in the setting.
See if that is your problem.
Pc-Mobile
http://pc-mobile.net/gps.htm
buster0007
PostPosted: Sun Jan 14, 2007 11:51 am    Post subject: Reply with quote
That’s just it there is no setting to switch it on and off just the settings in TT and I have gone through every one of them. But the GPS light comes on as soon as you flip it open with it being built in should I have a driver or utility in the PDA menu
Nielsdad
PostPosted: Thu Mar 15, 2007 11:57 pm    Post subject: Reply with quote
Sorry to hear about your trouble. I've been running TT6 on my N35 for a while now and I have had no trouble finding a GPS signal. My settings are:
other NMEA GPS receiver,
baud rate 9600
GPS ON NAVIGATOR
After a few seconds it usually starts searching for about 8 satelites. I have no other software running to make this happen.
As far as I can find there is no direct way to control the built in GPS under settings.
