Getalife Occasional Visitor
Posted: Sat Mar 25, 2006 11:03 pm Post subject: NAVMAN SPEED ACCURACY |
The vehicle I have the Navman in at the moment is always showing 5mph slower than the vehicle speedo, which I thought was quite accurate.
A vehicle I have just rebuilt has had the diff ratio changed and the speedo is not showing the true MPH. I want to use the NAVMAN speed function till the vehicle speedo is calibrated. Any views on how accurate the SATNAV reading is please. |
Posted: Sat Mar 25, 2006 11:33 pm Post subject: |
The GPS unit should be more accurate than any fitted speedo, this only applies when in a straight line and flat road - it is quite normal for the vehicle speedo to read a higher value than the one reported by the GPS, this could be down to the diff ratio (if messed with) and or tyre/ wheel size will further compound the problem, use the GPS speed and you will be OK, but if your speedo is out by a considerable margin you might want to consider getting it re-calibrated - Mike |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Sun Mar 26, 2006 1:04 pm Post subject: Re: NAVMAN SPEED ACCURACY |
Getalife wrote: | Any views on how accurate the SATNAV reading is please. |
If your speedo is only out by +5 MPH then to be honest it is probably within acceptable limits. Pretty much all cars overread by 5% or more, apparently this is a legal requirement.
If it were reading too low then I would get it recalibrated but otherwise don't worry about it.
Have a look at this thread for a detailed discussion.. _________________ Gone fishing! |
dk Occasional Visitor
Posted: Tue Apr 04, 2006 11:20 pm Post subject: |
Yes my Navman shows my speedo is 5mph over, it does on my friends car and my good lady`s car.So is it a coincidence our cars read 5mph out?
or is it the Navman? |
TerryWalsh Regular Visitor
Joined: Jul 29, 2005 Posts: 147 Location: Shrewsbury, UK
Posted: Wed Apr 05, 2006 8:43 am Post subject: |
Just about all car speedos show something like 5 MPH over. I think the manufacturers deleiberately err on the side of safety. I have a US built Focus ZX3 which I brought back to UK with me and its speedometer is always within 1 mph of the Navman display, but when I use the Navman in my wifes car and in several other cars their speedos always overread by 5 or more mph. In fact at 70 indicated in my wifes car the Navman only shows about 63 mph. |
ohreally Occasional Visitor
Posted: Sun Apr 09, 2006 1:19 pm Post subject: |
As a couple of posters have already alluded, the speedometer must not display a true speed which is less than actual speed thus munufacturers calibrate to show faster than true.They're are parameters they must operate within though and it will rarely be more than 3-4 mph over (though never under). |
anglefire Regular Visitor
Joined: 27/05/2003 22:32:53 Posts: 114 Location: Solihull, West Midlands, United Kingdom
Posted: Mon May 01, 2006 7:33 pm Post subject: |
My previous 2 cars (Both Audi's) read about 10% higher than the GPS indicated speed. Both my OriginB2 and 630 read the same within update time.
My current Audi reads about 4% higher than the GPS.
As I understand (And could easily be wrong!) the tollerance is 0% low 15% high. Ie can indicate faster than true but not slower. Between 3 and 10% seems typical. _________________ Mark
Website
The answer is 42. Now what is the question? |
MoPlain Occasional Visitor
Posted: Sat May 06, 2006 12:53 pm Post subject: |
I have the Navman ICN650 self contained unit and TomTom 3 and 5 on a PDA. The PDA can use one of three GPS receivers I have. If I am using both sat nav systems side by side both indicate the same speeds (and 98% of the time distances to next turns etc.). I use them in two different cars and the cars always read about 4-5 mph faster. |
123381 Occasional Visitor
Posted: Tue May 09, 2006 12:22 pm Post subject: |
my mitsubishi shogun sport is only 1mph out
Regards
Puddy |
zzf00l Regular Visitor
Posted: Fri Feb 09, 2007 8:15 am Post subject: |
I believe the legal requirement for speedometer accuracy is +/- 10mph |
Posted: Fri Feb 09, 2007 10:41 am Post subject: |
zzf00l wrote: | I believe the legal requirement for speedometer accuracy is +/- 10mph |
They are allowed to over read but not under read - you wouldn't want your speedo to read 10 MPH too slow! 8O _________________ Gone fishing! |
