Ratspom Occasional Visitor
![](modules/Forums/images/avatars/208979731843e9f9af56859.jpg)
Posted: Sun Jan 21, 2007 8:05 pm Post subject: IPAQ 3950 and TTNavigator v5 |
I have an ipaq 3950 running windows ce 3.0 I have upgraded my Ipaq's ROM version from 1.10.00 to 1.11.00 ENG unfortunately a consequence of doing the uprade meant losing all installed software. I reinstalled my original TT3 and uprade TT5 and latest TTv5.21, also I installed Checkpoint 5.2.
Now whenever I wish to use TT5 via Checkpoint 5.2 I have to firstly goto Start, settings, system, gps on the IPAQ and check that I have the com3 port tick box selected for TT Navigator GPS then I start the checkpoint 5.2 program and select Navigate and when TT5 is running goto Change Preferences, Show GPS Status , choose configure and select TomTom cable GPS and Ok only then will TT5 pick up satelites.
I'm sure I never had to do this routine before, once all the options were selected I simply started TT5 via checkpoint and away it went
I would be very grateful if someone could help me fix this
Many Thanks
MAc |
philpugh Lifetime Member
![](modules/Forums/images/avatars/gallery/bass_fret.jpg)
Posted: Mon Jan 22, 2007 3:00 pm Post subject: |
First,
un-install checkpoint and get TT5.21 working correctly. You should not have to set up the GPS each time.
Configure the GPS from the TomTom Settings pages.
Then re-install Checkpoint. I used to run Checkpoint 5 with TT5 versions and a cabled GARMIN GPS Mouse. I never had the problem you describe. I started Checkpoint and it started TT5 up and off I went. Eventually I 'ditched' Checkpoint as I wasn't using all the functionallity - I used the TT in-built POI warning - it's simple but it works well. |
Posted: Mon Jan 22, 2007 3:23 pm Post subject: |
Another thing.
It looks as if you may have a problem with your TT3 to TT5.21 as you shouldn't have a separate GPS driver with TT5.21.
When I replaced my iPaq 3660 with a Dell AXIM X51v I seemed to recal I installed TT V5 direcvtly - even though it was an upgrade. I seem to recall that it asked for the V3 product code.
If in doubt - do a hard reset and start from scratch.
Phil |
Posted: Mon Jan 22, 2007 5:23 pm Post subject: |
Ok,
Thanks for your suggestions PhilPugh. I'll uninstall CP5 and see how I get on. I'll report back later.
Ta
Mac |
