tonygold Frequent Visitor
Posted: Sat Dec 23, 2006 11:37 am Post subject: double camera alerts?? |
hi
tomtom ONE v2 europe.
have downloaded pgpsw camera database. all fine. except on certain cameras, notably red light ones i get the verbal warnings and certain boings as well, a couple of seconds later. this has also occured on a 40mph gatso.
reading thru the forums i suspect i must have the tomtom cameras also installed (by factory default??). i cannot see any on the sd card's map folder or listed on the units poi listing, so where are they? and how do i safely remove them so i only get your camera locations and warning voices.
many thanks. |
Andy_P Pocket GPS Moderator
Posted: Sat Dec 23, 2006 1:15 pm Post subject: |
Is another possibility that you may have accidentally installed two different versions of the PGPSW ones?
Either something like the single file version AND the speed-zoned set, or maybe you re-named them and then loaded a more recent set so it didn't automatically overwrite the old ones?
Quite a few people deliberately install them twice, with different warning distances and sounds, so for example you can have a generic sound a long way back, followed by a voice giving the speed as you get closer.
Check how many PGSW .ov2's you have. Assuming you use the full speed-zoned set, if you are up to date, there should be 24 categories, or 25 if you include the "empty" mobile_var file.
If you HAVE got the TomTom cameras, they should show up in the "Plus" menu. I don't have them so cannot say for definite, but I think they should still be fairly obvious if you browse inside the map folder. |
Posted: Sat Dec 23, 2006 2:06 pm Post subject: |
definatly only appear to have the 25 files needed. cant see a 'plus' folder in the western europe maps folder either??
baffled now!!!! |
DennisN Tired Old Man
Posted: Sat Dec 23, 2006 6:02 pm Post subject: Re: double camera alerts?? |
tonygold wrote: | how do i safely remove them so i only get your camera locations and warning voices. |
On my Tom Tom GO710 I was able to delete them whilst in Tom Tom HOME - it was the only way I could get rid of the wretched things!! If the ONE uses HOME, that seems to be the answer. By the way "25 files" - you don't do anything with the Mobile.var one, it's a dummy file, not a real camera POI. _________________ Dennis
Two of them are obesiting!! |
Posted: Sun Dec 24, 2006 12:31 am Post subject: |
tonygold wrote: | cant see a 'plus' folder in the western europe maps folder either??
Not a Plus folder, the Plus Menu on screen, which is where TT's own cameras are set up now (if you've got them). |
Posted: Sun Jan 07, 2007 9:01 pm Post subject: |
Tony, did you ever get this issue resolved? - if not please take a look at THIS Page, it should get rid of the annoying bongs/ beeps when approaching certain cameras - Mike |
Scotty-uk Regular Visitor
Joined: Dec 24, 2006 Posts: 61 Location: J7 M11 (Essex)
Posted: Sun Jan 07, 2007 9:36 pm Post subject: |
I have the same "feature" on my 910.
I've turned off the TomTom alerts, removed them all in Home, checked that I only have one installation of the Pocket GPS files and it still give me double warning on some of them. |
Posted: Sun Jan 07, 2007 10:30 pm Post subject: |
What happens if you remove the PGPSW ones. Do you get ANY alerts then? |
Posted: Sun Jan 07, 2007 10:33 pm Post subject: |
I've not tried yet but I will |
