Pocket GPS World :: View topic - Latest Speed Camera Database!
sandpiper
PostPosted: Thu Dec 21, 2006 1:46 pm    Post subject: Latest Speed Camera Database! Reply with quote
Crying or Very sad Hi just to make everybody aware. The latest database 13/12/06 has a corrupted file in it. Gatso.
missing_user
PostPosted: Thu Dec 21, 2006 1:52 pm    Post subject: Reply with quote
There are many different downloads for different units.
Be more precise!
Which database for which unit?
I have been using two different versions in two different units without problem.
I have also been using the .gdb file without problem.
PostPosted: Thu Dec 21, 2006 1:56 pm    Post subject: Re: Latest Speed Camera Database! Reply with quote
can you give some more info about this? such as which set of files etc. also, have you tried downloading the file again as this is the first complaint that we have received and I'm sure you can't be the first person to download it!
sandpiper
PostPosted: Fri Dec 22, 2006 10:10 am    Post subject: Reply with quote
Tom Tom Ov2, consolidated file. I have found that if you delete the pocket gps file name and just call it Gatso etc it works.
PostPosted: Fri Dec 22, 2006 10:47 am    Post subject: Reply with quote
so the file isn't actually corrupted then?
what "doesn't work" with it with it's original name?
PostPosted: Fri Dec 22, 2006 9:19 pm    Post subject: Reply with quote
Also "consolidated" is a term used with the SET of five files "consolidated into camera types", did you mean one of those files or the "all-in-one" single file?
Anyway as MaFt says, if re-naming it "cures" it it isn't corrupted.
Sounds like something wrong with file associations on your PC?
