Fellwalker Lifetime Member
![](modules/Forums/images/avatars/gallery/092.gif)
Posted: Sun Jan 14, 2007 2:54 pm Post subject: TT Home will not remove POI - TT6 and hx4700- help please? |
I have HP iPAQ hx 4700, fabulous machine.
Old TT5 was OK but postcodes a real frustration and maps old.
Got TT6, and it is much better.
BUT, i foolishly added all the POIs available, thinign I wouldbe able to enable and disable them at will.
now i find htat is limited.
It also means i cannot get teh pocket GPS world traffic camera database to work.
THE BIG PROBLEM is that if i go into TT Home, firstly it takes ages to check everything.
Secondly and most important - I ask it to delete any POI category, it asls for a confirmation, and tehn sits there for hours on end doing nothing.
If I cancel, the program freezes.
What can I do? |
alix776 Pocket GPS Moderator
Posted: Sun Jan 14, 2007 3:13 pm Post subject: |
use a card reader or active sync to access the map folder and delete only the ov2 a .bmp files that you want to get rid of _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Sun Jan 14, 2007 5:34 pm Post subject: |
Thanks, will do.
It just seems so ridiculous that hte software which should do the job does not. |
JockTamsonsBairn Lifetime Member
![](modules/Forums/images/avatars/202069601647f4a51ae4e4d.jpg)
Posted: Sun Jan 14, 2007 8:33 pm Post subject: Re: TT Home will not remove POI - TT6 and hx4700- help pleas |
Fellwalker wrote: | Old TT5 was OK but postcodes a real frustration and maps old. | What problems did you have with postcodes? _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Sun Jan 14, 2007 9:29 pm Post subject: Re: TT Home will not remove POI - TT6 and hx4700- help pleas |
BGF wrote: | Fellwalker wrote: | Old TT5 was OK but postcodes a real frustration and maps old. | What problems did you have with postcodes? |
TT5 only used hte first part of hte postcode plus hte first number of the second part. That was far too wide - several miles in the country particularly when I was looking for National Trust preoperties.
TT6 uses full ostcodes to search - though stupidly htey do not advettise that fact. |
Posted: Sun Jan 14, 2007 10:28 pm Post subject: Re: TT Home will not remove POI - TT6 and hx4700- help pleas |
Fellwalker wrote: | BGF wrote: | Fellwalker wrote: | Old TT5 was OK but postcodes a real frustration and maps old. | What problems did you have with postcodes? |
TT6 uses full ostcodes to search - though stupidly htey do not advettise that fact. | I can assure you that TTN5 has FULL postcode searching ![Exclamation](modules/Forums/images/smiles/icon_exclaim.gif) _________________ Jock
Posted: Sun Jan 14, 2007 11:28 pm Post subject: Re: TT Home will not remove POI - TT6 and hx4700- help pleas |
BGF wrote: | I can assure you that TTN5 has FULL postcode searching ![Exclamation](modules/Forums/images/smiles/icon_exclaim.gif) |
Clearly I never got it to work then... |
Quantum Frequent Visitor
![](modules/Forums/images/avatars/76041576644e0c2c07d95a.png)
Joined: 16/02/2003 03:21:58 Posts: 285 Location: Seattle, Ecotopia
Posted: Sun Jan 21, 2007 11:55 pm Post subject: |
Well, so are you saying that TTN6 does in fact run on the 4700? The 4700 is not on the list of devices its approved for.
I'll be getting the 6 upgrade soon, and would like to know, because TomTom's not responding to my question. |
Posted: Mon Jan 22, 2007 8:18 pm Post subject: |
Quantum wrote: | Well, so are you saying that TTN6 does in fact run on the 4700? The 4700 is not on the list of devices its approved for.
It certainly does. :D I am on hte original Windows Mobile 2003SE and have not upgraded to 5 (not sure if I am going to). |
markblades Occasional Visitor
Posted: Tue Jan 23, 2007 5:19 pm Post subject: |
Quantum:
I can confirm that the Hx 4700 is compatible when running WM5 (with the patch from HP).
No problems at all but then I don't use TThome for POI updating so Can't comment on that bit (just cut and paste the files in windows explorer it's much faster with WM5 as it is a USB 2 interface).
regards
Mark |
