Pocket GPS World :: View topic - Help , i can not see the icons on NUVI 660
pontes
PostPosted: Fri Dec 08, 2006 11:34 am    Post subject: Help , i can not see the icons on NUVI 660 Reply with quote
Hy ,
If some one can help me , i have about 14000 poi loaded my self into a nuvi 660 , in the first days of use i could see the icons on the map on navigating , but now , they do not show up in the map , but they are there in the folder (personal pois ) and i can acess them .
Is there any thing i can do to start again seeing those icons in the map on navegating ??
If i call a position or a POI and activate the MAP i can see them , but not during navigation...
Just hope someone can help me , thanks Sad
swing
PostPosted: Fri Dec 08, 2006 1:33 pm    Post subject: Reply with quote
Whether or not the POIs are visible is based on a number of obscure rules...
Firstly, they are more likely to appear in 2d mode than 3d mode, and even then it will depend upon the zoom level. Also, you might find more appear after navigating to a location (and arriving) - ie having had a route defined, but now complete.
Different firmware versions act slightly differently, so if you have upgraded the firmware this might explain the change you are now seeing.
Finally, different versions of POI Loader may affect this - there was one version with a bug which created alerts for every single POI you loaded onto the unit - which would result in many appearing on the screen (and beeping at you) even if you didn't want it.
Generally though, Garmin don't display the POIs (their own, or your Custom ones) on the screen all the time.
pontes
PostPosted: Fri Dec 08, 2006 7:50 pm    Post subject: Reply with quote
ok if i do not set a destination and go just on the MAP the POI icons show on the screen all of them and in the 3D .
I upgraded and have now the soft version 2,70
22.064 (26 Jun 24)
