ROBINP Occasional Visitor
Posted: Sun Sep 24, 2006 3:50 pm Post subject: SPEED CAMERA INFO FOR TOMTOM ONE |
Hi there,
just got tomtom one and need to download all camera info. Too much clutter on your website: I am looking at Garmin and UK single file with all cameras. Will that do the job?
Robin Pereira |
Posted: Sun Sep 24, 2006 4:11 pm Post subject: |
Robin, Welcome to the forum, please don't try loading Garmin data into a TomTom unit, it certainly won't work as intended.
Could I suggest you have a read of THIS OK this guide is for a different TomTom device, but all TomTom units have the same options/ set-up etc (Just skip the bit about using Text To Speech - as your unit doesn't support that) - Mike |
Anita Pocket GPS Moderator
Posted: Sun Sep 24, 2006 4:12 pm Post subject: |
Why are you looking at Garmin when you've got a TomTom? The Garmin files are csv files. I think you need TomTom OV2.
Have you tried the step-by-step instructions for TomTom One? You'll find the link in the left-hand column under Speed Cameras, Camera Help Guides? _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
Robin2 Lifetime Member
Posted: Sun Sep 24, 2006 6:24 pm Post subject: |
Mike, the instructions are very helpful.
I shall be buying a TomTom One Europe when they come out next month, after 3 years using a PDA which now deserves to be pensioned off. At present I use the separate speed zoned files, with CheckPOInt, so I have not encountered problems with the number of POIs. Do you know what the upper limit is for POIs in TomTom One, and does having a lot slow it down? The processor is not as fast as in my Ipaq 2210
Robin _________________ TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used |
Posted: Sun Sep 24, 2006 6:29 pm Post subject: |
The limit for the number of POI's depends upon the software your unit is running, if it is version 5 then you can only put 39 on the device, if on the otherhand it is either upgraded to version 6 or is a new purchase TomTom One V2 which uses version 6 - then the limit is 100.
I don't think it will slow the device down, the PNA's are different to the PDA's - Mike |
