kirkie Regular Visitor
Posted: Sat Sep 09, 2006 1:57 pm Post subject: Can I use this in my One? |
I have the standard SD card that came with my TT One and would like to get another. I am thinking of maybe a 1Gb, can anyone reccomend one and is this one any good?
http://www.directfoto.co.uk/shop/detail.aspx?productid=5980
Cheers |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Sat Sep 09, 2006 4:56 pm Post subject: |
As that one doesn't say Hi-Speed it probably will give you problems.
Any good make of SD Card, with a Hi-Speed Label should be OK. _________________ Richard
Posted: Sat Sep 09, 2006 5:48 pm Post subject: |
Oldboy wrote: | As that one doesn't say Hi-Speed it probably will give you problems.
Any good make of SD Card, with a Hi-Speed Label should be OK. |
Thanks for that, but what is a good make and will 1Gb be enough? |
Posted: Sat Sep 09, 2006 7:23 pm Post subject: |
I have both Kingston and Byte-Stor,
1GB should be OK for most uses. You can get 3 or 4 Maps on there. _________________ Richard
TonyHoyle Regular Visitor
Posted: Sat Sep 09, 2006 8:57 pm Post subject: |
Well one is an SD and one is a CF for a start.. good luck getting a CF to fit into a tomtom... |
Posted: Sat Sep 09, 2006 9:21 pm Post subject: |
TonyHoyle wrote: | Well one is an SD and one is a CF for a start.. good luck getting a CF to fit into a tomtom... |
Well least it has narrowed it down and I know which one to buy now...But thanks for your input... |
acer1355 Occasional Visitor
Joined: Sep 05, 2006 Posts: 18 Location: cambridgeshire
Posted: Sun Sep 10, 2006 5:11 pm Post subject: |
hope the sd card i have just bought will be ok .it,s a kingston 1gb, it does,nt say its hi speed. i have d/loaded gb map & poi on it & it works ok
it came from amazon £ 8 .49
regds acer 8) |
Posted: Sun Sep 10, 2006 6:53 pm Post subject: |
Is this one any good?
CLICK HERE
As it says: Speed Rating: 50x |
Tumbleweed Frequent Visitor
Posted: Sun Sep 10, 2006 9:00 pm Post subject: |
kirkie wrote: | Is this one any good?
CLICK HERE
there is another active thread called 'tt one cards' I suggest you check that out.
Tw |
