kirkie Regular Visitor
Posted: Wed Sep 13, 2006 11:57 am Post subject: Red Square |
I have just downloaded the new camera database to my TT One and for some reason the cameras are showing as red squares.
Any ideas? |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Wed Sep 13, 2006 1:36 pm Post subject: |
The indication of not having a bmp with the identical name to the ov2.;)
With Linux upper and lower case are not the same name, I believe. _________________ Richard
Andy_P Pocket GPS Moderator
Posted: Wed Sep 13, 2006 1:38 pm Post subject: |
That means that (for whatever reason) there is not a matching icon file for each camera file.
So for example, if you have:
pocketgps_uk_gatso_20.ov2
you also need:
Depending on which version of the database you are using, you will have upto 24 of each type of file.
So connect up to a PC and check the contents of your TomTom map folder to see if they are all there and are correctly named. |
Posted: Wed Sep 13, 2006 1:39 pm Post subject: |
Yet again, Oldboy!!!! ![Confused](modules/Forums/images/smiles/icon_confused.gif) |
Posted: Thu Sep 14, 2006 9:56 am Post subject: |
Andy_P2002 wrote: | That means that (for whatever reason) there is not a matching icon file for each camera file.
you also need:
Right thanks for that. I have downloaded it again, but it said it was there as it asked if I wanted to replace it so I said yes. I will let you know later if it has solved the problem. |
