jago25_98 Occasional Visitor
Posted: Sun Aug 27, 2006 10:49 am Post subject: Rename the POI files because - |
...they don't fit on the screen when using TomTom.
For example we have `pocketgpsworl_spee'[....], so you can't tell what speed camera the file is.
Could we rename this to '30mph_pocket'[...] or such like? |
Oldboy Pocket GPS Moderator
Posted: Sun Aug 27, 2006 11:22 am Post subject: |
You can rename them, but then both files have to be re-named. For ever, or until you're fed up.;)
If you hold your finger on the name, the font size will reduce allowing you to see the complete text. Drag your finger off the edge of the screen, so as not to select, or to another entry. _________________ Richard
Posted: Sun Aug 27, 2006 11:42 am Post subject: |
No, I mean I suggest the pocketgpsworld.com rename them before release |
Andy_P Pocket GPS Moderator
Posted: Sun Sep 03, 2006 10:17 pm Post subject: |
Seconded....
(or "PGPSW Gatso30" etc)
Any thoughts PGPSW? |
lupos0_1 Lifetime Member
Posted: Sun Sep 03, 2006 10:48 pm Post subject: |
Why??
Not being funny, but once you have them installed and your warn when near to distance is set, all you have to do is download the database and then override the original POI's. Not a lot of work really _________________ -------------------------------------------------------
Nokia N95
McGuider V7
Latest Maps
(Internal GPS) |
Posted: Sun Sep 03, 2006 11:33 pm Post subject: |
Sorry lupos0_1, I don't understand your answer.
What we mean is that a ) because of the very lonf filenames, with the specific bit at the far end, it is fiddly to see which file you are dealing with on screen; and b ) if we manually rename them (and the associated .bmps too) ourselves we have to re-do it for the ov2 files every month (and now maybe twice a month). |
Posted: Mon Sep 04, 2006 8:13 am Post subject: |
Andy_P2002 wrote: | Sorry lupos0_1, I don't understand your answer.
Must have the wrong end of the stick
Just out of curiousity, why do you need to deal with these individual files? _________________ -------------------------------------------------------
Nokia N95
McGuider V7
Latest Maps
(Internal GPS) |
bw2020 Pocket GPS Verifier
Joined: Aug 17, 2005 Posts: 121 Location: Tayside, Scotland
Posted: Mon Sep 04, 2006 9:56 am Post subject: |
I had this difficulty originally with the long filenames when trying to set up the correct warning sounds on Warn When Near.
However on upgrading to version 6.150 the bmp icon of the speed limit (speed zoned files) now appears at the start before the filename on my TT Go 500, so setting up the sounds on Warn When Near now is straightforward! _________________ Samsung A55 Android 14
CamerAlert v1.4.0.876 |
Posted: Mon Sep 04, 2006 2:37 pm Post subject: |
lupos0_1 wrote: |
Just out of curiousity, why do you need to deal with these individual files? |
As bw2020 says, the fiddly bit comes when you are are using the full speed-zoned set of ~24 files, and are trying to assign different warning distances and sounds to each. On the TomTom screen, all 24 files show up exactly the same, unless you do the trick of holding your finger on each one and squinting around underneath to read the rest in a small font. We're just suggesting abreviating the "PocketGPSWorld" bit or putting the speed and type first on each name. I can imagine it wouldn't be such a problem on a PDA version. |
peterc10 Frequent Visitor
Posted: Mon Sep 04, 2006 9:14 pm Post subject: |
Do I have my TT set up differently to everyone else I wonder?
When I go into the warn when near function as well as displaying the POI name in the list it also displays the associated bmp picture. So I can recognise instantly when I am dealing with the 30mph gatsos because the picture is of a 30 in a big red ring. So why do I need the rest of the name in that case? _________________ Peter
HTC Sensation
Copilot for USA
Posted: Tue Sep 05, 2006 6:08 pm Post subject: |
I can confirm that it depends on which version of TomTom you're running. The icon turns out ok on v6ish but no good on v5ish.
However I think the speed part of the filename is obscured even on v6? |
Posted: Tue Sep 05, 2006 6:58 pm Post subject: |
Nope that can't be the explanation since I am still using early version of TT5 (if it aint broke don't fix it principle). Icons showing good and clear on my list of POIs in the "warn when near" function. _________________ Peter
HTC Sensation
Copilot for USA
