Pocket GPS World :: View topic - How to transfer POI & Favorites?
Colinsp
PostPosted: Fri Sep 29, 2006 8:49 am    Post subject: How to transfer POI & Favorites? Reply with quote
I have been running TT5 for some while on a Palm T5 and have various favorites and POI stored. I have just bought a Go 700 can I transfer my old POI's etc to the 700? If yes what are the files I need to copy, the 700 has TT6 on it.
TIA
JockTamsonsBairn
PostPosted: Fri Sep 29, 2006 9:40 am    Post subject: Re: How to transfer POI & Favorites? Reply with quote
TIA
BGF wrote:
Traveller wrote:
I have just upgraded from Navigator 5 on my HP 2200 to a GO 910. How, assuming there is a way, can I export my TomTom favorites from the PDA and import them into the GO 910?
I have accumulated a lengthy list and entering them all manually would be time consuming and prone to human error.
BGF wrote:
philpugh wrote:
Does anyone know if there's a way to migrate your Favourites (locations) from V5.21 to V6? It's going to be a pain if you have to re-enter them all!
Phil
Happy 5.21 user
Have a look here.
Jock
Colinsp
PostPosted: Fri Sep 29, 2006 9:47 am    Post subject: Reply with quote
Thanks BGF but on clicking 'here' the no topic exits message comes up. Could you try again please?
lupos0_1
PostPosted: Fri Sep 29, 2006 11:21 am    Post subject: Re: How to transfer POI & Favorites? Reply with quote
TIA
To transfer your POI's, go into your map folder and find the named POI. There should be two files per POI that you need to copy across:
poi.ov2
(change poi for the name of the point of interest your copying)
As for your favourites, I believe that these are stored in the map.cfg file (change map for the name of the map you are using)
I am not sure if this can just be copied across, but you could try it.
As always, make sure you have a full back uyp of each device should things go wrong. Wink
Nokia N95
McGuider V7
Latest Maps
(Internal GPS)
Colinsp
PostPosted: Fri Sep 29, 2006 11:27 am    Post subject: Reply with quote
Thanks I'll try it
JockTamsonsBairn
PostPosted: Fri Sep 29, 2006 9:26 pm    Post subject: Reply with quote
Could you confirm that you are either not a subscriber or not logged in?
The salient info was:
Andy_P2002 wrote:
Well I'll answer that one here (but now you see why they hate double posts because the answers get scattered around? Wink ).
Its a manual process so depending how many favourites you have, it will take a little bit of time.
1 ) First, create a new POI category (Preferences / Manage POI / Add POI category ). Call it "Favs" or whatever you like.
2 ) Then go Preferences / Manage POI / Add POI / Favourite / and select your first favourite.
3 ) Repeat step 2 for each of you favourites.
The POI file will be found in your map folder, called "Favs.ov2" (if that's what you called it). Just copy that file (and its matching .bmp icon file) to your friends machine's map folder and enable it in the manage POI menu.
Jock
Colinsp
PostPosted: Fri Sep 29, 2006 9:51 pm    Post subject: Reply with quote
I was logged in but am not a subscriber but will subscribe.
JockTamsonsBairn
PostPosted: Sat Sep 30, 2006 12:51 am    Post subject: Reply with quote
The link that I had given pointed to the subscriber forum. I would have expected (hoped!) that there would have been a notice to explain.
Jock
22.062 (12 Jun 24)
