Pocket GPS World :: View topic - Is my Q2 knackered?
Is my Q2 knackered?
Aladdin_Sane
PostPosted: Wed Aug 16, 2006 7:11 am    Post subject: Is my Q2 knackered? Reply with quote
Briefly:- Had Q1 for a year with City Select v7, great bit of kit. Got a Q2 a few days ago with City Navigator NT v8 but screen takes a long time to re-draw.
Registered my Q2 as second unit and loaded City Select v7 maps hopeing it would re-draw screen quicker as it doesn't need to decompress the maps. Still no luck.
On way home from work this morning doing 85mph screen is going blank for 300yds at a time waiting to re-draw. Twice I 'Overtook' the maps and it had to re-calculate on just a 6 mile stretch!!
I exited left and aproached the roundabout and voice command said 'Take second exit' as it normally would. Screen went blank and didn't re-draw until 50 yards after the roundabout so would be no good without voice command.
Could it be a faulty unit?
Help please.
oddsock
PostPosted: Wed Aug 16, 2006 9:30 am    Post subject: Reply with quote
I Know you should not have to but have you tried turning off autozoom and setting your own mapscale ?
Is the Q2 the same as the Q1 in that when you install new maps they wipe the old ones from the system ?
TomTom one v1,tomtom one v 3,TT Start20,Garmin Oregon 300,Nuvi 300
Garmin Quest
elsinga
PostPosted: Wed Aug 16, 2006 9:31 am    Post subject: Reply with quote
Are you using the latest firmware? The 2.40 and 2.50 ondes were worse than the current one (although it's still a problem).
Robert Elsinga =8- )
GPS V FAQ Quest FAQ
Home @ N 52"55.812', E 05"51.509'
Aladdin_Sane
PostPosted: Wed Aug 16, 2006 2:46 pm    Post subject: Reply with quote
According to my Quest i'm using 2.80.
I'm gonna take both units to work tonight and see how they perform side by side.
I may well be selling a Q2 soon or asking Garmin to swap it for a Q1.
desd
PostPosted: Wed Aug 16, 2006 4:00 pm    Post subject: Reply with quote
It's not just me then im having the same problem the Q2 just doesn't seem upto the job it's being sold for.
My unit runs off the map every time i use it not just ocassionally £400 for not a lot so far.
Have also suffered with little or no sat reception when it's raining is this usuall ??
desd
PostPosted: Wed Aug 16, 2006 4:01 pm    Post subject: Reply with quote
Aladdin_Sane
PostPosted: Wed Aug 16, 2006 4:55 pm    Post subject: Reply with quote
Elsinga,
Whilst going through the Q1 and Q2 to make sure all the settings are the same I noticed in 'Map Info' that my Q2 is still running NT maps even though i've loaded V7 maps via mapsource.
I've just un-installed Mapsource from my pc and will re-install up to V7 when I get home from work later tonight.
Should the V7 maps replace the V8 maps by loading them onto my Q2??
elsinga
PostPosted: Thu Aug 17, 2006 9:40 am    Post subject: Reply with quote
The NT maps are preloaded and non-removable. Just switch them off if you want to try using CS7. BTW, I already did that and it was a minor improvement with firmware 2.40 and 2.50, but almost not noticable with 2.70 and 2.80.
GPS V FAQ Quest FAQ
bumpkin
PostPosted: Thu Aug 17, 2006 10:17 am    Post subject: Reply with quote
Are you saying that a Q2 with CS7 (non NT, was there a CS7 Europe NT?) is slower than a Q1 with the same mapping?
Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10
elsinga
PostPosted: Fri Aug 18, 2006 8:21 am    Post subject: Reply with quote
Yes. Not very surprising though, the Q2 has to deal with custom POI's where the Q1 does not. And I suspect that the firmware code to use the NT mapdata is also slowing the Q2-with-CS7 down a bit.
GPS V FAQ Quest FAQ
22.063 (19 Jun 24)
