Aladdin_Sane Regular Visitor
Posted: Wed Aug 16, 2006 7:11 am Post subject: Is my Q2 knackered? |
Briefly:- Had Q1 for a year with City Select v7, great bit of kit. Got a Q2 a few days ago with City Navigator NT v8 but screen takes a long time to re-draw.
Registered my Q2 as second unit and loaded City Select v7 maps hopeing it would re-draw screen quicker as it doesn't need to decompress the maps. Still no luck.
On way home from work this morning doing 85mph screen is going blank for 300yds at a time waiting to re-draw. Twice I 'Overtook' the maps and it had to re-calculate on just a 6 mile stretch!!
I exited left and aproached the roundabout and voice command said 'Take second exit' as it normally would. Screen went blank and didn't re-draw until 50 yards after the roundabout so would be no good without voice command.
Could it be a faulty unit?
Help please. |
oddsock Pocket GPS Verifier
Joined: May 01, 2004 Posts: 706 Location: Monmouthshire
Posted: Wed Aug 16, 2006 9:30 am Post subject: |
I Know you should not have to but have you tried turning off autozoom and setting your own mapscale ?
Is the Q2 the same as the Q1 in that when you install new maps they wipe the old ones from the system ?
Dave _________________ TomTom one v1,tomtom one v 3,TT Start20,Garmin Oregon 300,Nuvi 300
Garmin Quest |
elsinga Regular Visitor
Posted: Wed Aug 16, 2006 9:31 am Post subject: |
Are you using the latest firmware? The 2.40 and 2.50 ondes were worse than the current one (although it's still a problem). _________________ Robert Elsinga =8- )
GPS V FAQ Quest FAQ
Home @ N 52"55.812', E 05"51.509' |
Posted: Wed Aug 16, 2006 2:46 pm Post subject: |
According to my Quest i'm using 2.80.
I'm gonna take both units to work tonight and see how they perform side by side.
I may well be selling a Q2 soon or asking Garmin to swap it for a Q1. |
desd Regular Visitor
Posted: Wed Aug 16, 2006 4:00 pm Post subject: |
It's not just me then im having the same problem the Q2 just doesn't seem upto the job it's being sold for.
My unit runs off the map every time i use it not just ocassionally £400 for not a lot so far.
Have also suffered with little or no sat reception when it's raining is this usuall ?? |
Posted: Wed Aug 16, 2006 4:01 pm Post subject: |
Posted: Wed Aug 16, 2006 4:55 pm Post subject: |
Elsinga,
Whilst going through the Q1 and Q2 to make sure all the settings are the same I noticed in 'Map Info' that my Q2 is still running NT maps even though i've loaded V7 maps via mapsource.
I've just un-installed Mapsource from my pc and will re-install up to V7 when I get home from work later tonight.
Should the V7 maps replace the V8 maps by loading them onto my Q2?? |
Posted: Thu Aug 17, 2006 9:40 am Post subject: |
The NT maps are preloaded and non-removable. Just switch them off if you want to try using CS7. BTW, I already did that and it was a minor improvement with firmware 2.40 and 2.50, but almost not noticable with 2.70 and 2.80. _________________ Robert Elsinga =8- )
GPS V FAQ Quest FAQ
bumpkin Frequent Visitor
Joined: Feb 08, 2006 Posts: 264 Location: Herefordshire
Posted: Thu Aug 17, 2006 10:17 am Post subject: |
elsinga wrote: | The NT maps are preloaded and non-removable. Just switch them off if you want to try using CS7. BTW, I already did that and it was a minor improvement with firmware 2.40 and 2.50, but almost not noticable with 2.70 and 2.80. |
Are you saying that a Q2 with CS7 (non NT, was there a CS7 Europe NT?) is slower than a Q1 with the same mapping? _________________ Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10 |
Posted: Fri Aug 18, 2006 8:21 am Post subject: |
Yes. Not very surprising though, the Q2 has to deal with custom POI's where the Q1 does not. And I suspect that the firmware code to use the NT mapdata is also slowing the Q2-with-CS7 down a bit. _________________ Robert Elsinga =8- )
GPS V FAQ Quest FAQ
