Pocket GPS World :: View topic - My i3 has let me down in Europe
nudda
PostPosted: Sun Jun 25, 2006 2:26 pm    Post subject: My i3 has let me down in Europe Reply with quote
Sad
Went to France yesterday and thought I was all set for going to Belgium until I found my i3 would not recognise any of the places in beligum (not even brussels!).
Before I set off, I send data from my "City Navigator Europe v8" software for France, Belihum and Netherlands. It was around 350 mb which I put onto my microSD card. It all looked ok to me as the data was on the card for sure but when I got there it didnt want to know anything about bleigum or even Paris !
I dont know if this is due to fault of my own but I basically put the microSD into a card reader, opened up mapsource city navigator Europe v8, highlighted what I wanted on the card, and chose "Send to Device ..." from the Transfer menu. It all looked fine when transferred. Now I dont know if I needed to activate anything on the device or else where but I just put the card in and when I started up the i3 I get a quick progress bar (green one) at the beginning ... I am assuming this is when its reading the card.
Can someone please tell me what I might be doing wrong or am omitting.
Thank you
nudda
PostPosted: Sun Jun 25, 2006 10:53 pm    Post subject: Reply with quote
oh no I dont think I did that !
Do you know how ? (by the way, It didnt say anything about me not being allowed to transfer the maps to my microsd card).
zogman
PostPosted: Mon Jun 26, 2006 9:17 am    Post subject: Reply with quote
found this on the garmin site garmin faqs
PostPosted: Mon Jun 26, 2006 12:19 pm    Post subject: Reply with quote
i've never had to try this but i THINK that you need to have the i3 connected with the micro-sd card inserted and load maps via the i3 rather than directly to the sd card...
bumpkin
PostPosted: Mon Jun 26, 2006 4:11 pm    Post subject: Reply with quote
Again, not speaking from direct experience, that's how I thought it should be done as well.
Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10
afterall
PostPosted: Tue Jun 27, 2006 10:55 am    Post subject: Check if your maps are active Reply with quote
You can check to see whatmap sets are active on your i3.
Go into settings, select MAPS, scroll down to MAPSOURCE and if your transferred maps are active you should see two options ticked, one is the base map set within your i3 and below that should be the map sets you transferred over from your PC to the SD card.
Make sure both options are ticked.
I managed to transfer my map sets to the SD card and when installed into the i3 I do see two map set options available as stated above.
A
22.062 (12 Jun 24)
