Pocket GPS World :: View topic - DOWNLOAD CAMARA DATABASE
DIXYEMMIE
PostPosted: Wed Jun 14, 2006 11:11 pm    Post subject: DOWNLOAD CAMARA DATABASE Reply with quote
HI IAM NEW TO THIS DOWNLOAD LARK, I HAVE TRIED TO DOWNLOAD THE SPEED CAMARA FILE TO MY NAVMAN ICN 530 AND WHEN I GO TO THE POI FILE IT COMES UP WITH "UNKNOWN FILE FORMAT" WHAT IS THIS?PLEASE
THANKS Sad Sad
JockTamsonsBairn
PostPosted: Wed Jun 14, 2006 11:51 pm    Post subject: Re: DOWNLOAD CAMARA DATABASE Reply with quote
THANKS Sad Sad
Stop! Your CAPS LOCK is stuck on.
At what point does your problem occur?
Jock
DIXYEMMIE
PostPosted: Wed Jun 14, 2006 11:56 pm    Post subject: Reply with quote
Hi when i go into the POI Editor and go to open text file then go into folder for the file then click ok to open it comes up with the message
thanks Rolling Eyes
JockTamsonsBairn
PostPosted: Thu Jun 15, 2006 12:16 am    Post subject: Reply with quote
thanks Rolling Eyes
If I remember correctly, there are 2 different formats that you can use on the Navman (CSV & ASC?) one of them needs to be edited (first line deleted?). Is that any help?
Jock
PostPosted: Thu Jun 15, 2006 3:42 am    Post subject: Reply with quote
Are you sure you have downloaded the correct file type? you need the .asc files and these no longer require the text edit to the first line have a read through this guide http://www.pocketgpsworld.com/uksafetycameras-navman.php it explains the installation routine on the Navman system in detail
One other thought, you have un-zipped the downloaded file so it shows the different files withing the download before using the POIEditor? - Mike
DIXYEMMIE
PostPosted: Fri Jun 16, 2006 12:23 pm    Post subject: Reply with quote
Thanks guys problem solved.
Which of the 3 camera files is the best to download?
thanks
PostPosted: Fri Jun 16, 2006 1:09 pm    Post subject: Reply with quote
thanks
That depends on your preference. The single file version does not differentiate between camera types, the consolidated by type version does and the speed zoned version separates every camera by speed. Each one takes more time to install in that order with the speed zoned taking the most time.
22.071 (03 Jul 24)
