Pocket GPS World :: View topic - Tom Tom One Speed camera POI's
chrisparker
PostPosted: Wed Jun 14, 2006 11:30 pm    Post subject: Tom Tom One Speed camera POI's Reply with quote
Hi - help for a total beginner would be appreciated. Just downloaded POI's in form of bmp and ov.2 files and got them on PC. I think I have them on the TT device now, but am having to access through the TT icon in MyComputer rather than the Removable Disk option I have seen in instructions. I thought I had set up everything in the steps I have read on this site, but for some reason the camera icons are not displaying on the TT One. Calling up POI's on the One shows none held.
I am using TT One version 5.45. Do I need to change this to make it compatible with the download, and if I do will I be able to get 5.45 back from a restore in the future if I need to?
I feel really confused
oldfogy
PostPosted: Thu Jun 15, 2006 4:34 am    Post subject: Reply with quote
So, you have downloaded and unzipped the file, then placed the
bmp and ov2 files into the "Great Britain Map folder" (assuming it is GB you have)
Now start your TT and go to: Change preferences, then forward and select Manage POI, then Warn when near POI,
You now need to scroll down until you find the speed camera POI and select one of them, followed by assigning a sound from one on your system. Depending on which file you downloaded you need to do this with each POI camera.
Just re-read your post again and I think it may be you have not put the files (files only no folders) into the "Map folder"
Also check you downloaded the correct files for your TT One
and NO you do not need to change from 5.450 to anything else.
(If it ain't broke, I can soon fix it)
22.064 (26 Jun 24)
