Pocket GPS World :: View topic - Any intention to review GM270?
pdpuk
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Any intention to review GM270? Reply with quote
Just wondering whether there is any intention to review the Holux GM270 CF GPS?
Is this a "good" GPS, or are there "better" ones?
We will be reviewing it but don't have a review unit yet.
pdpuk
Thanks Dave
As with all the reviews look forward to this (whenever a review unit is obtained).
simkna
I have been using the GM270 for some time now and it's great. I am using it currently in SIRF mode with TTNav2 on a Toshiba e570, and have no problems at all. TTFF's are simply superb, and I can use it out of the car.
Si.
pdpuk, review units will be with us soon!
pdpuk
Excellent Dave - thanks for the update. Looking forward to this one and comparing it to other CF GPS receivers reviewed - it certainly seems to be gaining good comments from users.
We have two on the review bench at present, the 270 and 270U.
genes
I have been using the GM270 with my Axim and Tomtom 2.24 for a couple of months now and it works perfectly in both the normal mode and also Sirfs mode - Sirfs seems a little faster to lock on!
I would highly recommend this receiver and also the service from Holux UK
Terry
Axim X5 + Holux GM270 + Arkon multimedia mount + Brodit clip + Tomtom 2.24 & 2.07 + Checkpoint 2.2
Leeus
PostPosted: Thu Oct 16, 2003 10:21 pm    Post subject: Reply with quote
This may be obvious but where do I change between SIRF and NMEA??
PostPosted: Fri Oct 17, 2003 7:08 am    Post subject: Reply with quote
You can do it with WinFast Navigator. Here's some instructions...
http://www.pocketgpsworld.com/winfastnavigatorppc.php
Rich
PostPosted: Sat Nov 01, 2003 12:09 pm    Post subject: Reply with quote
can someone kindly enough to tell me what SIRF is?
Thanks,
Rich
PostPosted: Sat Nov 01, 2003 1:43 pm    Post subject: Reply with quote
SiRF is a chipset of the GPS Receiver. It is also a protocol used to access the chip directly. NMEA is also a protocol. Basically think of it like an intel chip, the protocol is the operating system set of instructions.
When a GPS receives data, it can output it in two different protocols. NMEA or SiRF. SiRF is obviously native to the chip as most receivers use SiRF chips, some use Evermore.
Most receivers tend to be configured for NMEA as this is the standard that most software products use to connect to GPS Receivers, so many software applications don't like natively talking SiRF.
david77
PostPosted: Tue Dec 02, 2003 12:17 am    Post subject: Reply with quote
I just purchased the GM-270 today and intend to add the Destinator-3 ( navigation application later next week. Both to be used with my MIO 558 pocket PC. I have few questions:
1) The default on the Holux seems to me to be NMEA. How do I switch to Sirf if and when needed? Does "Destinator" control it?
2) The default baud rate is 4800. I tried to change it to higher speed and it stopped working. Is there a way to change to higher speed when working with PDA to improve response time and performance?
PostPosted: Tue Dec 02, 2003 12:56 am    Post subject: Reply with quote
You will need to switch to SiRF using a program like WinFast Navigator. You won't see much benefit of using SiRF apart from putting the PPC Processor into a faster wait state. You can get faster position updates in SiRF but this can also cause more headaches running at a higher baud rate because it means you're more prone to losing a fix quicker.
Apples and Oranges really, personally unless you really want to use SiRF for a specific benefit, I'd stick with NMEA.
david77
PostPosted: Tue Dec 02, 2003 1:34 am    Post subject: Reply with quote
Thank you for the swift response. From your answer I understand that working in NMEA mode is limited to 4800. Sirf will allow working in higher speed.
Correct me if I am wrong?
Do you know if Destinator offers to choose between NMEA and Sirf?
22.064 (26 Jun 24)
