Pocket GPS World :: View topic - csv files and easygps
blueprint123
PostPosted: Mon Jun 12, 2006 5:50 pm    Post subject: csv files and easygps Reply with quote
I have gramin i3 streetpilot. I have transferred csv speed camera files to the unit successfuly , however i am not getting alerts. Also does any one have problems using easygps with the i3 model.
bumpkin
PostPosted: Mon Jun 12, 2006 9:36 pm    Post subject: Re: csv files and easygps Reply with quote
I assume that you used the Garmin POI loader with default settings to load the camera CSV files? Are proximity alerts set to on in the settings menu of the i3?
Your second question almost infers that you used EasyGPS to load the camera CSV files, presumably that's not the case? I've used Easy GPS on numerous occasions without problems (apart from the old version changing the text to Caps. New version doesn't do this) to add new favourites and edit existing ones. I think that's about its only use with an i3.
Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10
22.055 (29 May 24)
