BoldBelvoir Occasional Visitor
Posted: Wed May 17, 2006 7:10 pm Post subject: Favs to POIs? |
Is there a way I can turn Favourites into POIs from within TT5.21 without using any TPI software?
Cheers |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Wed May 17, 2006 7:28 pm Post subject: |
Yes.
In Manage POI you need to create a new POI category. Give it a name and select a bitmap.
In Browse Map, Find, Favourite, select your first entry. The map cursor will display the location.
Then tap the Cursor Icon at the bottom of screen, and select Add as POI, select your new category. If you want to keep the original text just press Done.
Do the same for all your Favourites.
You now have a POI of all your Favourites, which you can add even more to, and transfer from Device to Device and, more importantly, Backup.;) _________________ Richard
Posted: Thu May 18, 2006 11:15 am Post subject: |
Thanks for that. Seems rather long-winded, but it works!
Phil. |
wazzzzupmate Regular Visitor
Posted: Thu May 18, 2006 11:45 am Post subject: |
Seems long winded, but you will be glad you have done it when your pda loses its favourites. |
junger Occasional Visitor
Posted: Sun May 21, 2006 10:32 pm Post subject: bitmap |
hi
just reaing the tread, i have put my bitmap and the binary in the gb folder like the other poi' s but i cannot access them in the mio any ideas please |
Posted: Sun May 21, 2006 11:04 pm Post subject: Re: bitmap |
junger wrote: | hi
There is a limit of how many Categories TomTom will recognise. I believe it is 39 in TTN5.
Have you exceeded this limit? _________________ Richard
Posted: Mon May 22, 2006 12:05 am Post subject: |
thanks for the reply
no, i dont think i have, there are 15 active pio' s, the rest are not ticked
thanks |
Posted: Mon May 22, 2006 7:14 am Post subject: |
junger wrote: | thanks for the reply
thanks |
It's not the number of ticked POI's that are counted, but the total number loaded on the Device.
It is the number that you add yourself to check. Don't count those that are pre-installed.;) _________________ Richard
Posted: Mon May 22, 2006 12:30 pm Post subject: |
i can pick a basic icon, but cant get it to apply mt bitmap, could it be the size of the bitmap
Thanks |
Posted: Mon May 22, 2006 12:40 pm Post subject: |
your bitmap needs to be 22 x 22 pixels |
Posted: Mon May 22, 2006 8:38 pm Post subject: |
hi again
thanks for the info, works a treat.can i add phone numbers to the data acssociated with the information of the pio?
many thanks |
Posted: Mon May 22, 2006 9:29 pm Post subject: |
its ok , ive worked it out thanks |
cirrus363 Occasional Visitor
Posted: Wed Jun 07, 2006 2:18 pm Post subject: |
Hi Junger
I was interested in adding phone numbers to my POI's can you give a little guidance for an absolute beginner?
Thanks |
