henpecked Occasional Visitor
Posted: Sun Jun 04, 2006 11:44 pm Post subject: what map fits what |
Evening all,
I'll apolagise in advance because I know this question has been asked before but I did search and couldn't find the answer.
I'm going to frace in a few weeks so I thought I'd get a map when a friend of mine said he had all the maps for his tomtom on his phone so he lent me a disk (a copy) with a lot of plus(?) maps on it.
Can I get them to work on my go300 because the files in the map folders don't look the same. He has MMS files and I don't please help before I go and screw it all it up.
If his maps will work how do I put them on - is it just drag and drop
rodger |
alix776 Pocket GPS Moderator
Posted: Mon Jun 05, 2006 12:04 am Post subject: |
so but youll need to get your own copy of the maps for the go300 to be able to use them _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
lbendlin Pocket GPS Staff
Posted: Mon Jun 05, 2006 12:05 am Post subject: |
It's not that easy. First of all you need a valid product code. Then you copy the required map folder to the root of the storage card (use a card reader). And then when you want to use the map go to www.ttcode.com to create an activation code for that map from the product code and device ID that will be shown to you. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
shauneco Regular Visitor
Joined: Feb 10, 2006 Posts: 135 Location: Mansfield,Nottinghamshire
Posted: Mon Jun 05, 2006 1:41 pm Post subject: |
Yes it should work just drag and drop the plus map folder onto the root of the SD Card, Then on the TomTom select switch map and you should be able to choose between the maps. Although you may have to activate the maps if this is the case delete the plus folder off the SD Card and buy the maps you want from www.tomtom.com |
DavidHobbs Regular Visitor
Posted: Wed Jun 07, 2006 3:09 pm Post subject: |
Let us know if you get it to work. The maps are definitely worth the money if you end up having to buy them on your own. |
