Pocket GPS World :: View topic - cannot shut down tt2 after installing gps assist
rob-bob
PostPosted: Mon Oct 27, 2003 11:31 pm    Post subject: cannot shut down tt2 after installing gps assist Reply with quote
every time i try to shut down tt2 it restarts again within 10 seconds Confused
PostPosted: Tue Oct 28, 2003 7:30 am    Post subject: Reply with quote
This is because you either have GPSAssist, CheckPOInt or POI-Warner, running, and you are not shutting these programs down, or TTN2 isn't shutting them down on exit. Use the EXIT button in the Navigator screen.
You may want to perform a soft reset as it may have got confused.
rob-bob
PostPosted: Tue Oct 28, 2003 10:00 am    Post subject: gps assist Reply with quote
Yes i have gpsassist running, but when i shut down navigator from the exit screen before i can shut down gpsassist navigator restarts...is there a way of shutting gpsassist down first
many thanks
Rob
PostPosted: Tue Oct 28, 2003 12:08 pm    Post subject: Reply with quote
Yes, don't shut Navigator down, shut GPSAssist down and it will close Navigator.
rob-bob
PostPosted: Tue Oct 28, 2003 3:55 pm    Post subject: gpsassist Reply with quote
is there a way to switch between tt2 and GPSassist from the navigator screen
Rob
PostPosted: Tue Oct 28, 2003 5:18 pm    Post subject: Reply with quote
Yes, if you have a task management utility installed you can use this, or you can assign a hardware button to run GPSAssist and this should switch to it.
