Pocket GPS World :: View topic - Nuvi mounts for 350
Nuvi mounts for 350
carol
PostPosted: Sun May 21, 2006 9:28 pm    Post subject: Nuvi mounts for 350 Reply with quote
The standard mount that the 350 comes with is not really suitable for use in the motorhome, at least not in ours, as the windscreen is too far away and we don't seem to have a suitable place for mounting the fixed mount that is flat....
I have seen somewhere a photograph of the Nuvi with the Streetpilot soft mount (I used to have one!) but I don't see how it fixes, as I could buy another and this one was quite good. Also the fixed mount for the 2610 is still fixed on my dashboard, and I am loathe to try and get it off as it may damage the dash...
Does anyone know of a source of mounts other than the original one please.
Thanks in advance
Carol
Opportunity never goes away - It only goes to someone else!
cantgetlost
PostPosted: Sun May 21, 2006 10:10 pm    Post subject: Reply with quote
My van has a shaped dashboard, The fixed pad plate stuck well with only 2/3 of the adhesive pad in contact.
Extended arm fixings for garmin I3 may help as the ball is the same size and the nuvi cradle will pop straight on.
There are some details re I3 mounts around here somewhere Smile
matb
PostPosted: Sun May 21, 2006 10:56 pm    Post subject: Reply with quote
send a pm to mr.gonzales, the resident mount maker, with your ideas.
he has worked wonders for us i3 users. Wink
carol
PostPosted: Mon May 22, 2006 9:21 am    Post subject: Reply with quote
Thanks I did that yesterday late afternoon. Hoping he could help
Carol
swing
PostPosted: Mon May 22, 2006 9:42 am    Post subject: Re: Nuvi mounts for 350 Reply with quote
Have you considered the Garmin Automotive Mount? There are very few pictures showing how this works, as Garmin have not released a photo of the unit, but this may have been what you previous saw. Instead of the original mount with a suction pad on the end, it's a slightly smaller mount which clips into a base which you attach to the dashboad. It may (although this would need checking) be the same dimension as the Streetpilot soft mount you refer to.
Alternatively, there is the Brodit mount, which would attach to a vehicle specific mounting platform, which might be even better for your motorhome.
DracUK
PostPosted: Mon May 22, 2006 6:48 pm    Post subject: Reply with quote
Is this what you mean?
http://www.thenavigationcompany.com/products/GA010-10723-04_Garmin_Nuvi_Auto_Dash_Mount.html
Ordered one myself
DracUK
SpeedCam
PostPosted: Mon May 22, 2006 8:06 pm    Post subject: Reply with quote
Why not try a Brodit mount, just ordered my mount, not sure if they will have a suitable ProClips
carol
PostPosted: Mon May 22, 2006 8:52 pm    Post subject: Reply with quote
Drakuk - yes that looks like it - thanks a bunch. I will also check out the other suggestion as well
Tks
Carol
swing
PostPosted: Tue May 23, 2006 1:38 pm    Post subject: Reply with quote
Indeed it was - and well done for finding 1 of about 3 companies who actually have a picture of it!
22.063 (19 Jun 24)
