yesman72 Occasional Visitor
Posted: Tue May 16, 2006 3:24 pm Post subject: Can the default speed be changed in TTN5? |
When a routeplan is done, the default speed limits is used to calculate time for travel. Can these be changed as in TTN 3?
/Mike |
Silav101 Occasional Visitor
Posted: Tue May 16, 2006 5:12 pm Post subject: |
Nope. |
MarkHewitt Frequent Visitor
Joined: Nov 16, 2004 Posts: 1077 Location: Chester-le-Street & York
Posted: Wed May 17, 2006 3:01 pm Post subject: |
Actually that should be yes! Go into the preferences menu and look for road speeds, you can configure it from there.
From TomTom4 onwards this feature was removed. |
lupos0_1 Lifetime Member
![](modules/Forums/images/avatars/210896915648709d6ed5619.jpg)
Posted: Wed May 17, 2006 4:06 pm Post subject: |
As the question was directed for TT5, the answer remains NO _________________ -------------------------------------------------------
Nokia N95
McGuider V7
Latest Maps
(Internal GPS) |
alix776 Pocket GPS Moderator
Posted: Wed May 17, 2006 7:20 pm Post subject: |
actually the answer is yes using the limited speed option if you set the speed to say 50 mph then the eta will change as tt5 caluculates that can not acheive a spped of over 50mph so the roads speeds have changed ![Wink](modules/Forums/images/smiles/icon_wink.gif) _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Wed May 17, 2006 9:32 pm Post subject: |
- pokes Alix -
Ah, but he asked if you could _change_ the speeds, not use a limited speed to manipulate the route; also the result of that routing would be different if one could manually alter the default speeds. :-)
Po-taytoe, poh-tahtoe.
