Pocket GPS World :: View topic - Tomtom One - white scree
julians
PostPosted: Thu May 18, 2006 10:43 pm    Post subject: Tomtom One - white scree Reply with quote
I think I may have broken my tomtom one.
When I power it on, I just get a completely white screen, I have tried resetting it, but it makes no difference. The unit wont respond to anything other than the power switch and the reset button. The PC wont recognise it when I plug it into the USB.
I thought I'd see if the maps (from my legally bought copy I might add) from my tomtom 5 for my ipaq would work on this, so I fired up the map installation program and selected to install the spanish map , and then selected to install it onto the tomtom go (closest to a tomtom one I thought), which it detected and proceded to install. It all copied across fine, then when the unit rebooted it displayed the tomtom go screen, but then froze, and now I just get a white screen.
Have I completely it? I couldnt find any other posts with this same problem.
I cant update the application as the PC doesent see the device.
PostPosted: Fri May 19, 2006 10:48 am    Post subject: Reply with quote
Sounds like you might have.
Did you do anything to it, or did it just (not) wake up like that one day?
PostPosted: Fri May 19, 2006 10:50 am    Post subject: Reply with quote
Damn this "no editing" bug on this board!
I meant to add, you should still be under guarantee, its usually 2 years for TomTom products. Check your small print.
Eldar
PostPosted: Fri May 19, 2006 11:06 am    Post subject: Re: Tomtom One - white scree Reply with quote
card reader might help
PostPosted: Fri May 19, 2006 2:38 pm    Post subject: Reply with quote
Have you got the TomTom plugged in via an addaptor (multi-way USB Hub)? If so unplug the hub and try a direct connection with the PC, also try a different cable, it might be damaged - Mike
Chris_UK
PostPosted: Fri May 19, 2006 6:08 pm    Post subject: idea? Reply with quote
only a small idea but try switching it on with the media card out?
Eldar
PostPosted: Fri May 19, 2006 6:19 pm    Post subject: Reply with quote
if there is no physical damage to the screen, the most likely casue is a software conflict between the bootloader and the application.
22.055 (29 May 24)
