999tommo Frequent Visitor
![](modules/Forums/images/avatars/102097806847b5aca54fdd8.jpg)
Posted: Sun Apr 30, 2006 10:27 pm Post subject: Changing Menu Order |
I have installed the POI Capture facility and believe you can alter the menu (tomtom.mnu) using Notepad. I have opened the menu file in notepad to try to edit it but the list of cammands (listed below) does't seem to correspond to what I have on screen. All I really want to do is move the capture tool from page 4 of the menu to page 1 and move something I don't use to page 4. According to the list below, there isn't a page 4, but there definately is... Any ideas ??
MENUBLOCK|BLOCK_MAIN|BTM_GPS_POSITION|
MENUPAGE|TASK_PAGE1|Main menu 1 of 3|
MENUITEM|TASK_NAVIGATE_TO|
MENUITEM|TASK_SDK1|
MENUITEM|TASK_DELETE_ROUTE|
MENUITEM|TASK_SWITCH_SOUND|
MENUITEM|TASK_MENU_ROUTE_INSTRUCTIONS|
MENUITEM|TASK_PAGE2|
MENUPAGE|TASK_PAGE2|Main menu 2 of 3|
MENUITEM|TASK_EXIT_APP|
MENUITEM|TASK_MENU_FIND_ALTERNATIVES|
MENUITEM|TASK_ITINERARY|
MENUITEM|TASK_SWITCH_NIGHTVIEW|
MENUITEM|TASK_ADD_FAVORITE|
MENUITEM|TASK_PAGE3|
MENUPAGE|TASK_PAGE3|Main menu 3 of 3|
MENUITEM|TASK_SWITCH_POI|
MENUITEM|TASK_MAINTAIN_POI|
MENUITEM|TASK_MENU_PREFERENCES|
MENUITEM|TASK_SHOW_MAP|
MENUITEM|TASK_MAINTAIN_FAVORITES|
MENUITEM|TASK_PAGE1| _________________ Tommo...
Regularly absent, but still here in spirit ! |
Oldboy Pocket GPS Moderator
Posted: Sun Apr 30, 2006 11:04 pm Post subject: |
Where have you put the tomtom.mnu File?
It should be in the SdkRegistry. _________________ Richard
Posted: Sun Apr 30, 2006 11:20 pm Post subject: |
It appears to be in the root directory. The Menu operates correctly and I can page through the four pages with the POI Capture being the only item on page 4. I want to move this to page one. When I use notepad to edit the menu, it brings up the data as shown on my previous post. I can't even see any reference to POI capture, let alone page 4. _________________ Tommo...
Posted: Sun Apr 30, 2006 11:56 pm Post subject: |
Thanks Oldboy.....
I have now moved the tomtom.mnu file from the root directory to the sdk registry folder and the POI Capture appears on page 1, but all the other icons have been rearranged too. Clear Route has gone from page 2 to page 1 which is good, but Change Preferences has moved from page 1 where I like it, to page 3. Exit Application has appeared on page 2 and that never existed before.
If I could keep the menu identical to the original except putting POI Capture on page 1 and moving Tom Tom Traffic (which I don't use) to page 4, that would be fab.
Can this be done ? If not I'll just leave Capture on page 4, which makes inputting a camera on the move a bit awkward. I have been on the menu builder site (skux.net) but several of the icons differ from mine and POI Capture doesn't exist. _________________ Tommo...
