Pocket GPS World :: View topic - help- lost maps?
help- lost maps?
sexygazza
PostPosted: Sun Mar 26, 2006 8:23 pm    Post subject: help- lost maps? Reply with quote
hi - i'm new to sat nav, so i'm hoping someone can help. i've just purchased a streetpilot i3 and used it to get home - all well so far - but when i got home i thought i would update the software, so i did, however now the problem is i seem to have lost the maps and i can't see on the garmin site how to get them back or if i can download a replacement.
hope someone can help.
thanks in advance
Aitch2
PostPosted: Sun Mar 26, 2006 9:16 pm    Post subject: Reply with quote
Updating the i3's firmware using WebUpdater app should not affect the maps at all...these are held on the SDMedia memory card slotted into the rhs of the unit - are you sure that this is plugged in properly? (remove then replug with power off...)
What makes you think you've lost your maps? The 'load maps' error message on the i3 at start-up is usually caused by dirty contacts on the aforementioned SDMedia memory card - these can best be cleaned using a normal pencil eraser (again, ensuring power off when removing or reinserting media...)
Aitch
Find Somewhere Else 090407: www.marillion.com
sexygazza
PostPosted: Sun Mar 26, 2006 10:21 pm    Post subject: Reply with quote
ok - problems seems to be solved, i've just gone out for a drive and it seems 2b working ok. thanks
22.054 (22 May 24)
