Pocket GPS World :: View topic - Problem editing POI file names (can't enter zeros)
Skyrideruk
PostPosted: Mon Jan 29, 2007 2:09 pm    Post subject: Problem editing POI file names (can't enter zeros) Reply with quote
I am experiencing the following problem when transferring POI (speedcam) files onto my 530 using SmartST Desktop:
Having selected the required file, I am required to enter a file name before sending it to the 530. Since I am using the zoned version (24 files) I obviously have to give each of them a different name. What I am trying to do is enter something like GAT20, MOB30, SPECS40 etc. but it will not allow me to enter a 0 (zero) although I can enter other numbers okay.
I am working around this by entering a capital O instead of a 0, but would like to know if this can be fixed?
Thanks.
Tim Buxton
PostPosted: Mon Jan 29, 2007 6:00 pm    Post subject: Reply with quote
The only way I've found is if you rename the file to what you want before using the Navman POIEditor. It will use the zero if it's already in the file name.
Tim
Skyrideruk
PostPosted: Mon Jan 29, 2007 7:15 pm    Post subject: Reply with quote
Hi Tim,
Thanks for your reply - so it's not just me after all Laughing
Yes, that definitely works, thank you.
I note that the POIEditor comes up with the same first 8 letters of the file name (POCKETGP) if you don't edit them first. Just wondering if it would be possible for the authors to address this & start using some different file names when producing future databases - just a thought...
Tim Buxton
PostPosted: Mon Jan 29, 2007 7:57 pm    Post subject: Reply with quote
No, it's not just you. IIRC then the 2006 and/or 2006SE version doesn't suffer from this problem.
Tim
Skyrideruk
PostPosted: Tue Jan 30, 2007 1:51 pm    Post subject: Reply with quote
Okay, thanks for the further info.
Robin2
PostPosted: Tue Jan 30, 2007 9:12 pm    Post subject: Re: Problem editing POI file names (can't enter zeros) Reply with quote
I had this the other day when trying to enter data into a spreadsheet. I found that I had accidentally pressed the Num Lock key on my laptop and it was typing an asterisk instead of a zero. All the other numerals were OK
Robin
TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used
Skyrideruk
PostPosted: Tue Jan 30, 2007 10:24 pm    Post subject: Reply with quote
Hi Robin,
Thanks for your reply.
I can confirm that the Num Lock is definitely off when this issue occurs.
I have recently contacted Navman support about this & received a reply from them today which confirms that this is a "feature" of this software.
Thanks for the suggestion though.
zzf00l
PostPosted: Fri Feb 09, 2007 2:27 pm    Post subject: Reply with quote
Mine too! I just use the letter o instead of 0... works for me
22.063 (19 Jun 24)
