Paul-in-Cornwall Occasional Visitor
Joined: Oct 02, 2005 Posts: 17 Location: Hertfordshire
Posted: Tue Mar 14, 2006 12:30 am Post subject: Has anyone used Limited Speed option? |
Just been trying some routes demos using limited speed from my house to some local places and I keep seeming to get the same results as if I used shortest route, anyone found this option useful??
Paul |
SpeedCam Frequent Visitor
Joined: Mar 18, 2004 Posts: 753 Location: Biggleswade, BEDS
Posted: Tue Mar 14, 2006 12:56 am Post subject: |
I tried it once, because we tow a caravan I used the limited speed option, TomTom did provide some interesting alternatives. Unfortunately I wasn't brave enough to use the routes, as I was worried I would be taken down some tight, narrow lanes, no good with a caravan on the back |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Tue Mar 14, 2006 8:08 am Post subject: |
It's only function appears to be to give you a revised ETA, and the opportunity to view our wonderful countryside, from the inside. _________________ Richard
TT Via 135 App 12.075: Europe Map v1135 |
lupos0_1 Lifetime Member
Posted: Tue Mar 14, 2006 10:20 am Post subject: |
Never really given it a thought. I can understand caravan towers using this option but apart from that, I can't really see any use for it! _________________ -------------------------------------------------------
Nokia N95
McGuider V7
Latest Maps
(Internal GPS) |
Posted: Tue Mar 14, 2006 7:43 pm Post subject: |
All it does is limit any road, that has a faster allocated speed than your 'set speed', to have that same timing.
In practice, it will take you on a straighter route using smaller roads, and the perceived speed of Motorways and fast Dual Carriageways has removed their advantage.
The use of lower class roads then puts the Larger Vehicles at a disadvantage by taking them down smaller roads. _________________ Richard
alix776 Pocket GPS Moderator
Posted: Tue Mar 14, 2006 10:45 pm Post subject: |
I use limited speed everyday it usually gives me a sensable route if I use shortest or fastest then I get routes that are inappropriate for my veihcle _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Tue Mar 14, 2006 11:55 pm Post subject: |
alix776 wrote: | I use limited speed everyday it usually gives me a sensable route if I use shortest or fastest then I get routes that are inappropriate for my veihcle |
Sounds like the guy who got his lorry suck recently near Saltash in a small out of the way village and took hours to reverse out, just makes me think the settings of this feature should the other way around, ie: minimum speed instead of maximum...
Paul |
Posted: Tue Mar 14, 2006 11:58 pm Post subject: |
Oldboy wrote: | All it does is limit any road, that has a faster allocated speed than your 'set speed', to have that same timing.
The use of lower class roads then puts the Larger Vehicles at a disadvantage by taking them down smaller roads. |
Same as Shortest route then, just a different ETA time as mentioned above.
Paul |
Posted: Wed Mar 15, 2006 9:50 am Post subject: |
I stand corrected _________________ -------------------------------------------------------
Nokia N95
McGuider V7
Latest Maps
(Internal GPS) |
Ginger Lifetime Member
Joined: 02/07/2003 18:39:46 Posts: 38 Location: Warrington UK
Posted: Wed Mar 15, 2006 2:04 pm Post subject: |
As a truck driver I use limited speed on a regular basis. It does the opposite of what you would expect it to do. It uses the best possible road to get to a destination and only takes you off A roads and M'ways at the last point possible. It will take you round a destination to the far side to keep you on a M'way, so using minor roads for the least possible distance. _________________ Alan |
