wonderdust Occasional Visitor
Posted: Tue Jan 10, 2006 1:10 am Post subject: Help tomtom go300 speed camera installation |
I am trying to install the speed cameras on a go 300 but to no avail. I have tried followng the instructions on this site on how to do it but cannot get it to work at all. Is there anyone out there that has the time to give me a step by step idiots (me) guide on how to install it.
Many thanks in advance
Muckylugs |
rayflan Frequent Visitor
Joined: 30/12/2002 17:36:20 Posts: 4916 Location: Oxfordshire, England, UK
Posted: Tue Jan 10, 2006 12:31 pm Post subject: |
Hi wonderdust,
to the forum!
Yes I know that you've been a member since 2004, but it is your first post. ;)
There are some guides that should be read (in the following order):
The beginner’s guide to the PocketGPSWorld camera database.
This explains about the different camera types and about categories and subcategories, so that you can decide how you want the database on your unit.
Depending on whether you have TomTom Navigator on a Pocket PC or TomTom GO, please read either:
How to install (camera database) POIs to TomTom Navigator 5.
This guide explains how to load the PocketGPSWorld camera database onto a Pocket PC running TomTom Navigator 5.
How to install (camera database) POIs onto a TomTom GO, Rider, or One.
This guide explains how to load the PocketGPSWorld camera database onto your TomTom GO, Rider, or One.
Once you have installed, set up, and used the PocketGPSWorld camera database for a while on your TomTom SatNav system. You may want to share and send in details of cameras yourself. You can do this by using the PocketGPSWorld POI Capture utility:
The PocketGPSWorld POI Capture utility.
You do not need the PocketGPSWorld POI Capture utility on your TomTom SatNav system in order to use the PocketGPSWorld camera database. However if you want to send in camera details then POI Capture makes the process of recording cameras much easier on TomTom Navigator and GO (original, 300, 500, and 700). At the moment POI Capture will not work with TomTom Rider, One, and mobile. This is for a technical reason, which we hope, will soon be rectified by TomTom.
The above guides may look lengthy and complicated when first seen. However if you grab a cup of coffee and read each one thoroughly then they should make sense as they have been written in a step-by-step way, for ease of reading.
Garmin Camper 770 LMT-D |
pjohn Occasional Visitor
Posted: Wed Jan 11, 2006 12:10 am Post subject: tt go 300 speed camera problems |
Hi I too have followed all the instructions for downloading and installing the files in the GB map folder to no avail I find I have no camera poi installed on my tt unit and the add POI icon is greyed out so unable to add Can anyone please help
Thanks John |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Wed Jan 11, 2006 7:51 am Post subject: Re: tt go 300 speed camera problems |
pjohn wrote: | Hi I too have followed all the instructions for downloading and installing the files in the GB map folder to no avail I find I have no camera poi installed on my tt unit and the add POI icon is greyed out so unable to add Can anyone please help
Thanks John |
The Add POI Icon is grayed out because there are no categories installed that you can Add to.
Did you Copy the paired ov2 and bmp files only, or did you copy the Folders, to the Map Folder? _________________ Richard
TT Via 135 App 12.075: Europe Map v1135 |
Posted: Thu Jan 12, 2006 12:19 am Post subject: greyed out symbols |
Hi All thanks for everything I downloaded eac file individually and now am ok thanks again
John |
