Pocket GPS World :: View topic - virgin requires help?
randyshooter
PostPosted: Mon Feb 27, 2006 5:27 pm    Post subject: virgin requires help? Reply with quote
hi please help!
i have recently purchased ttnav5 (wired) which i am using on my ipaq 1710. i have been very happy with it and have found the basics very easy to use. what i want to know is. as i dont have bluetooth or a mobile with email, can i get speed camera, traffic details put on? also can i download a different voice (homer would be good). lastley what is tomtom plus? is this only for people with a bluetooth handset? if not does it offer value for money?
sorry if these seem like stupid questions, we all have to start someware!!!
peterc10
PostPosted: Mon Feb 27, 2006 5:49 pm    Post subject: Reply with quote
You can download the camera database using your pc and syn it across using whatever cables and software comes with the Ipaq (Activesync?). Follow the instructions on this site (click on the "How tos" in the Speed camera box on the left hand side of this screen). Better hurry though because within the next few days you will have to pay for the info.
You can do the same with voices that you can find in many places - but be warned the celebrity ones wear very thin very quickly. I recomend you try the voices at http://www.tomtomsatnav.info/. I use Liz.
Others can tell you about TT Plus - I don't use it.
Peter
HTC Sensation
Copilot for USA
Bury CC9060 bluetooth car kit & Brodit mount
Privateer
PostPosted: Mon Feb 27, 2006 6:03 pm    Post subject: Reply with quote
Hi randyshooter,
I’m afraid that I don’t know the HP rz1710, I tried to find its specifications on the HP site but couldn’t. Does the rz1710 have Bluetooth capabilities and you don’t have any other Bluetooth equipment, or does the rz1710 not have Bluetooth capabilities?
Yes you can install a speed camera database and you don’t need Bluetooth to do this. Have a look at the PocketGPSWorld camera database here.
If you want Traffic, then you will need Bluetooth capabilities on both your iPAQ PDA and your mobile phone. You also need a network tariff that allows GPRS as not all Pay As You Go network tariffs allow GPRS transfers. I know that Orange PAYG does though! ;)
If you want to add extra voices then yes you can, we have advertisers that sell voices. Please check them out on the right hand side of the page.
If you wish to download extra stuff and you have the original TomTom (SD) storage card then you would be well advised to get a larger one. E.g. a 256MB, 512MB, or even a 1GB storage card.
I don’t know if you need Bluetooth capabilities for all of the TomTom Plus services, you certainly do for Traffic. It’s best if you have a look here for further information.
The golden rule of this forum is that there is no such thing as a stupid question, if you don’t know you ask. You quite rightly said that everybody has to start somewhere, and every single person on this forum was a beginner once. Thumbs Up
Robert.
Garmin Camper 770 LMT-D
randyshooter
PostPosted: Mon Feb 27, 2006 7:16 pm    Post subject: Reply with quote
hi robert thanks for the info. however i have just tried to add the POICapture.CAB file. which shows up on my ipaq settings page but now tomtom wont work it has just frozen, any ideas?
Privateer
PostPosted: Mon Feb 27, 2006 7:24 pm    Post subject: Reply with quote
Hi randyshooter,
You don’t need POI Capture to use the PocketGPSWorld speed camera database. POI Capture is used to make the recording of camera sites much easier.
If you do want to use POI Capture fore recording new or updating existing site (and please do) then please ensure that you downloaded the correct version for your Pocket PC and that you didn’t download the TomTom GO one.
Are you using the original SD card, if you are what is its size? You may need to get a larger card and copy the entire contents of the original card to the new card.
Robert.
randyshooter
PostPosted: Mon Feb 27, 2006 7:27 pm    Post subject: Reply with quote
any idea how can i delete poi capture from ipaq or restore settings?
randyshooter
PostPosted: Mon Feb 27, 2006 7:38 pm    Post subject: Reply with quote
what have i done?
when i switch ipaq on tomtom is frozen. none of the buttons help at all?
peterc10
PostPosted: Tue Feb 28, 2006 11:24 am    Post subject: Reply with quote
Start with a soft reset. if that does not work a hard reset should - but you will loose all your settings
Peter
HTC Sensation
Copilot for USA
randyshooter
PostPosted: Tue Feb 28, 2006 6:11 pm    Post subject: Reply with quote
panic over a soft reset did the job. thank you all for the advice.i am considering downloading the speed camera info. with only having a ipaq rz1710 will the processor be good enough to cope?
tanda
PostPosted: Wed Mar 01, 2006 1:34 am    Post subject: Reply with quote
Hi Randy, I have an iPAQ rz1710, with ViaMitchelin, and the camera database from this site. The 1710 is just about big enough(memory wise) to run the softwear, but you MUST get a bigger SD card. With VM, if I tried to plan a long route the 1710 would throw up an error, with a bigger card, the 1710 uses the card to calculate a route, so get a bigger card, and get as much as you can on the card, and leave the memory on the 1710 to be used to run the PDA. To answer Privateer's question, no the 1710 hasn't got bluetooth, it is very basic, with a small memory, hence the need for a larger SD card.
Audi A3 Sline sat nav
peterc10
PostPosted: Wed Mar 01, 2006 1:44 am    Post subject: Reply with quote
Should be Ok, but tick the hide all POIs in change preferences, because showing all of them takes a lot of memory. This is not the same as "warn wjhen near POIs", which you can set up seperately for your cameras and which does not use any where near as much memory.
Peter
HTC Sensation
Copilot for USA
22.064 (26 Jun 24)
