Pocket GPS World :: View topic - tomtom 5 acer n35 probs
dazzer12
PostPosted: Fri Dec 30, 2005 12:35 pm    Post subject: tomtom 5 acer n35 probs Reply with quote
Hi tried installing tomtom 5 on acer n35 set gps unit as nmea other and tried various baud rates from 2400 to 57600 set as gps on navigator the problem is tomtom sees the gps unit but will not aquire a satellite signal yet the very poor destinator software gets 7 or 8 satellites in no time can anyone help?
MikeyF
PostPosted: Fri Dec 30, 2005 2:47 pm    Post subject: Acer N35 Reply with quote
I've got TT working fine. You need to select
Other Cable NMEA GPS
I've got my baud rate set at max (115200) - works fine
Now select GPS ON NAVAGATOR
Once this is done, soft reset your Acer and wait for it to come back to life.
Now stand outside, flip open the antenna and start-up tomtom.
Once this is running click on the signal strength bar (bottom right) now the same bar (top right) this takes you to a similar screen as in D3.
In the top right corner you should see a small blue and yellow circle spinning. This indicates it's looking for satelites. (it takes a while on the first attempt but speeds up on subsequent attempts)
If the circle isn't spinning do a soft reset and sart again.
This should fix all problems whereby it can't get a fix, but remember tobe patient as it takes a few minutes on the first attempt.
Mikey
22.063 (19 Jun 24)
