Pocket GPS World :: View topic - Advanced Planning problem TomTom500
c7
PostPosted: Thu Jan 05, 2006 5:27 pm    Post subject: Advanced Planning problem TomTom500 Reply with quote
hi again!
I need help again:
As soon as the Advanced Planning function has it's calculated the route between two locations it automatically re-calculate the route from my current position! Not very advanced at all!
Anybody come across this before?
I've tried the reset button, but have yet to try restoring from the back-up cd I made.
Everything else seems to work fine.
Any suggestions?
Question
Oldboy
PostPosted: Thu Jan 05, 2006 9:30 pm    Post subject: Reply with quote
I'm afraid it's the way it works. Yours is a common complaint.
You'll need to lose the Sat Lock to get it to work as you want.
TuurG
PostPosted: Thu Jan 05, 2006 9:37 pm    Post subject: Reply with quote
what version are you running? This functionality has changed a bit, at least since v5.0. Earlier versions always recalculated after a few seconds, if you had a gps 3D fix.
If you plan a route from A to B, you get the summary. If you press OK, you go back to the normal navigation view en route is recalculated.
But if if you press Route from the summary, then you get options to view or demo your route. As long as you stay within this menu, the route is not recalculated from your current position. The moment you leave the route menu, you go back to the navigation view and the route is recalculated again.
GO1005
MGC GT 1968
MGB Cabrio 1973
AlanK
PostPosted: Fri Jan 06, 2006 12:34 am    Post subject: Reply with quote
I got the impression that it was more for pre planning when you weren't able to get your current position
Works ok on my PDA tho as the GPS is simply turned off but I can see that it is pretty much useless on the GO if your outside, unless you get yourself a BIG metal box for your and your go Wink
PostPosted: Fri Jan 06, 2006 2:13 am    Post subject: Reply with quote
Never been a problem for me.
What TuurG says is how it is supposed to work. After it has worked out the A-B route and shown the summary, just press Route and you get all the usual options to view as text, pictures etc. or demo your route.
When done, going back to normal mode is just what you'd want isn't it?
c7
PostPosted: Fri Jan 06, 2006 12:28 pm    Post subject: Reply with quote
aaaah! i seee! Smile
thanks for that - i guess after the first time it happened I couldn't see the 'ROUTE' button for looking! Embarassed
22.054 (22 May 24)
